Reading this thread atm, pretty amusing/mental. Hope he gets all the way.
http://www.pistonheads.com/gassing/...5458&mid=153233&nmt=So,+am+I+destined+to+fail
Thats amazing!
Thats amazing!
It depends which Team Banana it is. There were top-end ones, some ok ones and some made from gas pipe, all with the Team Banana name and colour scheme. There are a couple of ways to tell them apart. Typically, the weight is a giveaway. The top-end ones had two bottle cage mounts. Seatpost size is another giveaway: 25.4mm is gas pipe, 27mm or 27.2mm is Reynolds 531/753 etc. On top of that it's going to be down to the groupset that came with it. If it's a chromed steel Huret or Raleigh jobbie it's the bottom end model.Second hand prices related, but slightly more on the 'retro side'. Does anyone know how much an original Raleigh Team Banana roadie would be worth?. My old man has one he was about to chuck out at the weekend but I told him to hang fire until I checked if they were worth anything. It's in excellent condition despite having been sat for years doing nothing but gather dust in the garage.
...to recover from the dehydration.
Sounds like he's struggling a bit with his body, and his route sounds a bit mental. Maybe he'll manage it, though.
I think when my time comes I'll be planning it a wee bit more rigorously than this...
Why were you dehydrated?
Fail to plan = Plan to fail.
Didn't drink enough!
Weather was much hotter than I expected too, 2 unplanned 20% hills didn't help (but will encourage me to pay more attention to my map reading).
Can I make a well intentioned suggestion? Always take 2 bottles out with you. Make sure that at least one of them has a Nuun or Zero tablet in it. Take 2 additional tablets and a £5 note wrapped in a food bag in your jersey pocket. When you're getting low, stop at a garage and buy a bottle of mineral water, transfer to your bottle, pop a tab in and away you go.
something to bear in mind is that you'll need two tabs for a normal size bottle.
that Nuun at least.
anyone got any ideas how long it should take me to do this?
http://ridewithgps.com/routes/1479204
I figured if I earmark 3-4 hours each way I should be about right?
looking to get some bigger miles under my belt over the summer.
Really? I use 1 Zero tablet per bottle - standard Elite sized bottles as well.
I think you should manage it comfortably in under 4 hours.
each tabs good for 16ozReally? I use 1 Zero tablet per bottle - standard Elite sized bottles as well.
Says on the side of the standard Zero tablets 2x tabs per 750ml for strong 1x for weak.
