**CRAZY END OF MONTH DEALS ON AMD/ATI GRAPHICS CARDS - DO NOT MISS OUT!!**
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
I am offering some crazy AMD end of month deals, thats right you need to have ordered these before 5pm tomorrow, as at this time the prices goes back up. These prices are the lowest in the UK, so don't miss out:-
Gigabyte ATI Radeon HD 7970 Windforce 3X 3072MB GDDR5 PCI-Express Graphics Card - AMD 3 for FREE Promotion @ £339.95 inc VAT
GIGABYTE introduces the latest exclusive "Triangle Cool" Technology to reach a better cooling performance. The latest patent pending technology combines fin with clip module in a special triangle shape. With the original anti-turbulence structure plus the new triangle cooling design, it enhances the efficiency of heat dissipation dramatically by minimizing the flow of turbulence between fans. Therefore, the "Triangle Cool" Technology provides a more efficient air flow for the cooling system.
Ultra Durable VGA board provides dramatic cooling effect on lowering both GPU and memory temperature by doubling the copper inner layer of PCB. GIGABYTE Ultra Durable VGA can lower GPU temperature by 5% to 10%.
Ultra Durable VGA board reduces voltage ripples in normal and transient state, thus effectively lowers noises and ensures higher overclocking capability. GIGABYTE Ultra Durable VGA graphic accelerators improve overclocking capability by 10% to 30%.
Ultra Durable VGA board allows more bandwidth for electron passage and reduces circuit impedance. The less circuit impedance, the more stable flow of current and can effectively improve power efficiency. GIGABYTE Ultra Durable VGA can lower power switching loss by 10% to 30%.
Features:-
- PCI-E 3.0 Ready: Delivers double the bandwidth per lane of PCIe GEN2 for faster GPU- CPU
- Fastest single GPU graphics card on the planet
- Hugely overclockable
- Vastly cooler running than previous generation
- Quieter running than previous generation
- Compute Power: 3.5 TFLOPS
- Core Clock Speed: 1000MHz
- Primitive Rate: 2 prim / clk
- Shader Architecture: GCN
- Stream Processors: 32 CU / 2048 ALU
- Texture Units: 128
- ROPS / Z-Stencil: 32 / 128
- Frame Buffer / Memory: 3GB GDDR5
- Memory Width / Speed: 384 bit / 5500MHz
- Load / Idle Board Power: <300W / <3W
- Power Connectors: 8-pin + 6-pin
- Dimensions: H=38 mm, L=285 mm, W=126 mm
- Display Outputs: 1xDVI + 2x mDP + 1x HDMI
- 3yr Warranty
- AMD 3 for FREE Promotion including Dirt 3 Showdown, Nexuiz, Deus Ex Games (Subject to availability)
Was [£359.99] Inc. VAT
Only £339.95 inc VAT.
ORDER NOW
MSI HD 7970 3072MB GDDR5 PCI-Express Graphics Card - AMD 3 for FREE Promotion @ £299.99 inc VAT
As AMD is going to launch its latest HD 7000 series GPU on Jan. 9th, 2012, MSI also will release R7970-2PMD3GD5 graphics card at the same time. MSI R7970-2PMD3GD5 has exclusive GPU Overvoltage support through MSI's Afterburner utility allowing amazing overclocked performance from the get-go. Equipped with 3GB GDDR5 memory allows for the unprecedented memory bandwidth levels needed to run today visually hottest DirectX 11 titles at extreme resolutions across multiple displays. Stability is guaranteed through the use of All Solid Capacitors making sure the R7970-2PMD3GD5 and R7950-2PMD3GD5 have an ultra-long lifespan even under the stress of continuous gaming. DisplayPort 1.2 and HDMI 1.4a connectors allows all new audio and video formats like Blu-ray 3D Stereo, "Deep Color" (for true natural color representation) and 7.1 High Bitrate audio to be presented on up-to six displays through AMD's Eyefinity Technology.
MSI's R7900 series graphics cards are the first graphics cards in the world to support the new PCI Express Gen 3 format. With a processor and mainboard that has PCI Express Gen 3 capability, users will be able to enjoy maximized gaming performance via the ultra-high 32GB/S bandwidth. The R7900 series graphics cards have also adopted the brand new AMD 28nm graphics chip to provide higher performance computing compared to previous generation 40nm products.
MSI's R7970-2PMD3GD5 graphics cards are equipped with the popular Afterburner tuning software, allowing users to adjust the core voltage and improve overclocking potential. In addition, Afterburner also features bundled Predator in-game video capture, remote monitoring capabilities via mobile phone, as well as Kombustor GPU stress testing and other amazing features at no extra charge, providing an exceptional software suite for users of the HD 7000 series graphics cards.
MSI's R7900 series graphics cards support AMD's exclusive Eyefinity multi-monitor display technology. The expanded field of view is perfect for professionals and hardcore gamers. The new MSI R7900 series cards support next-generation Display Port 1.2 and HDMI 1.4a interfaces with stereoscopic 3D capability, as well as 7.1 channel lossless high quality TrueHD and DTS-HD audio formats, providing users with the best audio and visual experience possible.
MSI's R7970-2PMD3GD5 has adopted all solid capacitors. The aluminum core is capable of maintaining a high degree of stability even when working under full loads over extended periods of time. With a 10-year lifespan, MSI rids users of concerns over potential crashes or delays that are caused by system hardware overheating, further providing users with the best computing experience possible.
Features:-
- Core Clock Speed: 925MHz
- 3yr Warranty
Was [£349.99] Inc. VAT
Only £299.99 inc VAT.
ORDER NOW
Powercolor HD 7970 LCS Edition 3072MB GDDR5 PCI-Express Graphics Card - AMD 3 for FREE Promotion @ £359.99 inc VAT
The World's first 28nm GPU. The revolutionary new GCN Architecture. Ready for DirectX 11.1. PCI Express 3.0. The AMD Radeon™ HD 7970 is your personal checklist for ground-breaking technology. The next generation of AMD Eyefinity technology is here, featuring all-new support for stereo 3D, universal bezel compensation and brand new display configurations. Face it: the best just got better. Armed with the new PCI Express 3.0 standard, multi-GPU configurations with AMD CrossFire™ technology are just another way to obliterate the competition with the revolutionary AMD Radeon™ HD 7970. Leave no performance behind. Get higher clocks and faster gaming with AMD PowerTune technology on AMD Radeon™ HD 7970 Graphics. Fold and mine faster than ever with AMD App Acceleration powered by the unprecedented 28nm GCN Architecture. The market isn't ready for 4K video, but Radeon™ is. With full support for 3GHz HDMI 1.4a and DisplayPort 1.2 HBR2, the AMD Radeon™ HD 7970 is set for Quad HD.
- Fitted with EK Nickel Acetal Waterblock
- Core Clock: 1050MHz
- Memory: 3072MB GDDR5
- Memory Clock: 5700MHz (Effective)
- Memory Interface: 384-Bit
- Processing Cores: 2048
- Bus Type: PCI-Express 3.0
- Display Connectors: 1x Dual Link DVI, 1x HDMI & 2x Mini-DisplayPort
- HDCP Capable
- DirectX 11 Support
- OpenGL 3.2 Support
- ATI CrossFire Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- ATI HD3D Technology
- Warranty: 2 Years
Was [£419.99] Inc. VAT
Only £359.99 inc VAT.
ORDER NOW
VTX3D HD 7970 X-Edition 3072MB GDDR5 PCI-Express Graphics Card - AMD 3 for FREE Promotion @ £319.99 inc VAT
VTX3D HD7970 X Edition incorporates the latest PCI-E Gen 3 to get the maximum performance from your GPU. Both fitted with 3GB of GDDR5 memory connected via a new high speed 384 bit memory interface. VTX3D HD7970 X Edition is clocked at 1050MHz, also together with 5700Mhz for memory, fulfilling those who thirst for extreme performance. The HD7970 X Edition also features ultra cooling design. With two 92mm ultra big fan and SSU-shape heat pipe design, this efficient cooling solution maximizes the speed of heat dissipation, but minimizes the noisy level, creating most pleasing environment for gaming.
VTX3D HD7970 X Edition offer gamers with advanced DirectX® 11, including faster Tessellation and DirectCompute, bringing intense gaming performance and unrivalled image quality with ultra-realistic imagery. With AMD PowerPlay technology support, ensuring maximum GPU efficiency by dynamically scaling clocks speeds and power consumption in response to GPU loads. Enhancements for AMD Eyefinity technology include multi-display stereoscopic 3D support and 16k x 16k group resolution, gamers can get the most intense gaming performance than before.
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
Only £319.99 inc VAT.
ORDER NOW
XFX HD 7970 3072MB GDDR5 PCI-Express Graphics Card - AMD 3 for FREE Promotion @ £299.99 inc VAT
nonl2brThe World's first 28nm GPU. The revolutionary new GCN Architecture. Ready for DirectX 11.1. PCI Express 3.0. The AMD Radeon™ HD 7970 is your personal checklist for ground-breaking technology. The next generation of AMD Eyefinity technology is here, featuring all-new support for stereo 3D, universal bezel compensation and brand new display configurations. Face it: the best just got better. Armed with the new PCI Express 3.0 standard, multi-GPU configurations with AMD CrossFire™ technology are just another way to obliterate the competition with the revolutionary AMD Radeon™ HD 7970. Leave no performance behind. Get higher clocks and faster gaming with AMD PowerTune technology on AMD Radeon™ HD 7970 Graphics. Fold and mine faster than ever with AMD App Acceleration powered by the unprecedented 28nm GCN Architecture. The market isn't ready for 4K video, but Radeon™ is. With full support for 3GHz HDMI 1.4a and DisplayPort 1.2 HBR2, the AMD Radeon™ HD 7970 is set for Quad HD.<br>
<br>
- Core Clock: 925MHz<br>
- Memory: 3072MB GDDR5<br>
- Memory Clock: 5500MHz (Effective)<br>
- Memory Interface: 384-Bit<br>
- Processing Cores: 2048<br>
- Bus Type: PCI-Express 3.0<br>
- Display Connectors: 1x Dual Link DVI, 1x HDMI & 2x Mini-DisplayPort<br>
- HDCP Capable<br>
- DirectX 11 Support<br>
- OpenGL 3.2 Support<br>
- ATI CrossFire Ready<br>
- ATI Eyefinity Technology<br>
- ATI Avivo HD<br>
<br>
<iframe width="560" height="315" src="http://www.youtube.com/embed/VQI8lhHFQ9Q" frameborder="0" allowfullscreen></iframe>
- Warranty: 2 Years
Was [£339.95] Inc. VAT
ORDER NOW
Asus HD 7950 TOP 3072MB GDDR5 PCI-Express Graphics Card - AMD 3 for FREE Promotion @ £239.99 inc VAT
The next generation Asus HD7950-3GD5 graphics card has arrived, fitted with a 28nm GPU that packs 4.3bn transistors and is combined with 3GB GDDR5 Memory, it provides users with the speed for smoother gaming. Supporting full DirectX 11, AMD CrossFireX and AMD HD3D, the GPU includes an exclusive tweak utility which allows users to tune the performance of up to four graphics cards and check card status via an intuitive interface.
This GPU Tweak function links the GPU clock frequency to the voltage, so as you scale the GPU clock the voltage automatically follows; a useful tool for inexperienced Overclockers, It also enables users to select between 2D and 3D mode by providing the ability to change the respective clock speeds, voltages and fan speeds of either. Disabling the 2D mode also forces the faster 3D mode, stabilising overclocking and benchmarking results.
Embedded with GPU-Z to access accurate graphics card information, the card also contains a live update driver and BIOS benefiting users with the ability to keep their card in the best condition. Widget monitoring provides the choice to display the most needed information including a full widget, light widget or real time monitoring.
Furthermore, new PCI Express 3.0 delivers improved encoding and twice the performance of the previous PCI Express 2.0 and vision horizons can be expanded across six displays with AMD Eyefinity technology. This technology delivers innovative graphics display capabilities enabling massive desktop workspaces and ultra-immersive visual environments for the ultimate panoramic computing experience.
- Cranked 100MHz over reference for an ultimate engine clock of 900MHz
- Dual fan DirectCU thermal delivers 20% cooler performance with direct heat dissipation and runs significantly quieter at 600% greater airflow
- GPU Tweak provides a professional yet intuitive graphics tuning interface for real time card adjustment and monitoring
- The latest PCIe 3.0 bus standard delivers improved encoding for twice the performance of current PCIe 2.0
- Expand visual horizon across six displays with AMD Eyefinity technology
- Core Clock Speed: 900MHz
- Stream Processors: 32 CU / 1792 ALU
- Memory Width / Speed: 384 bit / 5000MHz
- 3yr Warranty
Was [£299.99] Inc. VAT
Only £239.99 inc VAT.
ORDER NOW
Gigabyte ATi Radeon HD 7950 Windforce 3X 3072MB GDDR5 PCI-Express Graphics Card @ £249.95 inc VAT
Features:-
- Core Clock: 900MHz
- Memory Clock: 5000MHz (Effective)
- Processing Cores: 1792
- HDCP Capable
- ATI Avivo HD
- Warranty: 3 Years
Was [£289.99] Inc. VAT
Only £249.95 inc VAT.
ORDER NOW
HIS HD 7950 IceQ 3072MB GDDR5 PCI-Express Graphics Card - AMD 3 for FREE Promotion (H795Q3G2M) @ £239.99 inc VAT
The World's first 28nm GPU. The revolutionary new GCN Architecture. Ready for DirectX 11.1. PCI Express 3.0. The AMD Radeon™ HD 7950 is your personal checklist for ground-breaking technology. The next generation of AMD Eyefinity technology is here, featuring all-new support for stereo 3D, universal bezel compensation and brand new display configurations. Face it: the best just got better. Armed with the new PCI Express 3.0 standard, multi-GPU configurations with AMD CrossFire™ technology are just another way to obliterate the competition with the revolutionary AMD Radeon™ HD 7950. Leave no performance behind. Get higher clocks and faster gaming with AMD PowerTune technology on AMD Radeon™ HD 7950 Graphics. Fold and mine faster than ever with AMD App Acceleration powered by the unprecedented 28nm GCN Architecture. The market isn't ready for 4K video, but Radeon™ is. With full support for 3GHz HDMI 1.4a and DisplayPort 1.2 HBR2, the AMD Radeon™ HD 7950 is set for Quad HD.
- Core Clock: 800MHz
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
ORDER NOW
HIS HD 7950 3072MB GDDR5 PCI-Express Graphics Card - AMD 3 for FREE Promotion (H795F3G2M) @ £239.99 inc VAT
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
Was [£279.95] Inc. VAT
ORDER NOW
VTX3D HD 7950 X-Edition 3072MB GDDR5 PCI-Express Graphics Card - AMD 3 for FREE Promotion @ £249.95 inc VAT
VTX3D HD7950 X Edition incorporates the latest PCI-E Gen 3 to get the maximum performance from your GPU. Both fitted with 3GB of GDDR5 memory connected via a new high speed 384 bit memory interface. VTX3D HD7950 X Edition is clocked at 880MHz, also together with 5000Mhz for memory, fulfilling those who thirst for extreme performance. The HD7970 X Edition also features ultra cooling design. With two 92mm ultra big fan and SSU-shape heat pipe design, this efficient cooling solution maximizes the speed of heat dissipation, but minimizes the noisy level, creating most pleasing environment for gaming.
- Core Clock: 880MHz
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
ORDER NOW
Gigabyte ATI Radeon HD 7850 OC Windforce 2X 2048MB GDDR5 PCI-Express Graphics Card w/ Nexuiz & Dirt Showdown PC Games @ £184.99 inc VAT
Using high quality components on graphics cards is the key factor for having a long lasting, stable and reliable product. GIGABYTE is again setting a new standard by using Ferrite Core Chokes, Low RDS (on) MOSFET and Lower ESR Solid Capacitors, providing the stability and reliability from their high-end graphics solution. In addition, GIGABYTE Ultra Durable 2 Edition graphics cards now feature a sophisticated layout topology. This state-of-the-art power design from GIGABYTE delivers the ideal integration of thermal, electric characteristics, digital signals, power circuitry and optimum placement of components for enhanced graphics performance.
The special inclined dual fan design effectively minimizes the flow of turbulence between two fans and enhances heat dissipation of hot area right underneath each fan. By unique design, WINDFORCETM 2X even enlarges air channel on the graphics card vents and creates a more effective air flow system in chassis. This special design helps heat dissipate quickly from GPU. In addition, WINDFORCETM 2X is equipped with 2 copper heat-pipes which strengthen the speed of heat dissipation.
Supporting multiple independent display outputs simultaneously, AMD Eyefinity technology delivers innovative graphics display capabilities enabling massive desktop workspaces and ultra-immersive visual environments for the ultimate panoramic computing experience.
Features:-
- Core Clock: 975MHz
- Memory: 2048MB GDDR5
- Memory Clock: 4800MHz (Effective)
- Processing Cores: 1024
- ROPS: 32
- Bus Type: PCI-Express 2.1
- Display Connectors: 1 Dual Link DVI-I, 1 HDMI & 2x Mini-DisplayPort
- HDCP Capable
- Shader Model 5.0 Support
- OpenGL 4.0 Support
- ATI Avivo HD
- Warranty: 3 Years
- Supplied with Nexuiz & Dirt Showdown PC Games
Was [£199.99] Inc. VAT
Only £184.99 inc VAT.
ORDER NOW
Gigabyte ATI Radeon HD 7870 OC Windforce 3X 2048MB GDDR5 PCI-Express Graphics Card w/ Nexuiz & Dirt Showdown PC Games @ £214.99 inc VAT
Features:-
- Core Clock: 1100MHz
- Processing Cores: 1280
- ROPS: 32
- HDCP Capable
- ATI Avivo HD
- Warranty: 3 Years
Was [£239.99] Inc. VAT
Only £214.99 inc VAT.
ORDER NOW
VTX3D HD 7870 2048MB GDDR5 PCI-Express Graphics Card w/ Nexuiz & Dirt Showdown PC Games @ £199.99 inc VAT
With continued demand for increased graphics horsepower to support more visually intensive games, the AMD Radeon HD 7800 Series is set to power the next generation of games and applications. And for those looking to upgrade to a next-generation graphics card, the AMD Radeon HD 7800 Series is the ideal choice.
- Core Clock: 1000MHz
- Memory Interface: 256-Bit
- HDCP Capable
- DirectX 11.1 Support
- OpenGL 4.2 Support
- ATI Avivo HD
- Warranty: 2 Years
Was [£229.95] Inc. VAT
Only £199.99 inc VAT.
ORDER NOW
VTX3D HD 7870 2048MB EyeFinity 6 GHZ Edition GDDR5 PCI-Express Graphics Card w/ Nexuiz & Dirt Showdown PC Games @ £239.99 inc VAT
VTX3D proudly presents the HD 7870 Eyefinity 6 graphics card, the world's first Radeon HD 7000 series graphics card to feature 6 mini DisplayPort outputs, and harnesses the power to unleash incredible scalability, productivity and immersive HD gaming performance, making it the definitive solution for those who refuse to compromise. Get ready for the future with 28nm GPU technology, Graphics Core Next Architecture, AMD App Acceleration and support for Ultra HD 4096p resolutions and PCI Express 3.0.
- Display Connectors: Mini DP x 6
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
ORDER NOW
Asus HD 5450 SILENT 512MB GDDR3 PCI-Express Low Profile Graphics Card @ £18.99 inc VAT
The ATI Radeon™ HD 5450 graphics card offers everything you need for gaming and HD home entertainment in one package. Do more on your PC with ATI stream technology, which accelerates even the most demanding applications. See more with ATI Eyefinity technology, providing the ultimate gaming experience by allowing up to three displays from a single graphics board. The ATI Radeon™ HD 5450 fully supports Microsoft DirectX® 11 which enables real-time rendering with ultra-realistic characters and incredible 3D imagery.
ATI Eyefinity Technology allows two or more display outputs operating simultaneously and cooperatively with one another. Support is available for Duplicated (Clone), Extended Monitor and Single Large Surface mode (SLS). SLS mode is capable of grouping multiple displays into a massive single large display for use with desktop workspace, video playback, with support for both windowed and full screen 3D applications.
- Exclusive 0dB thermal design dissipates heat efficiently without any noise
- Low profile design with low profile bracket bundled
- GPU Guard doubles structural reinforcement to prevent crackings
- Full DX11 support for amazing image quality
- Passive cooling design (SILENT)
- Core Clock: 650MHz
- Memory: 512MB GDDR3
- Memory Interface: 32-Bit
- Memory Clock: 900MHz (Effective)
- Processing Cores: 80
- Display Connectors: 1 VGA, 1 Dual-Link DVI-I & 1 HDMI
- HDCP Capable
- ATI Avivo HD
- Excellent for Media playback
- Support DXVA & surround sound over HDMI
- Dimensions: 7 " x 5.43 " Inch
- 3yr Warranty
Was [£23.99] Inc. VAT
Only £18.99 inc VAT.
ORDER NOW
MSI HD 5450 1024MB GDDR5 Low Profile PCI-Express Graphics Card @ £19.99 inc VAT
nonl2br
The ATI Radeon™ HD 5450 graphics card offers everything you need for gaming and HD home entertainment in one package. Do more on your PC with ATI stream technology, which accelerates even the most demanding applications. See more with ATI Eyefinity technology, providing the ultimate gaming experience by allowing up to three displays from a single graphics board. The ATI Radeon™ HD 5450 fully supports Microsoft DirectX® 11 which enables real-time rendering with ultra-realistic characters and incredible 3D imagery.</p>
ATI Eyefinity Technology allows two or more display outputs operating simultaneously and cooperatively with one another. Support is available for Duplicated (Clone), Extended Monitor and Single Large Surface mode (SLS). SLS mode is capable of grouping multiple displays into a massive single large display for use with desktop workspace, video playback, with support for both windowed and full screen 3D applications.</p>
<br>
<font size="3"><b>Key Features</b></font></p>
<b>Military Class Concept Components</b><br>
- SSC (Solid State Chock) has No Buzz noise and higher current for better overclocking ability.<br>
- All Solid CAP for longer lifespan.<br>
<br>
<b>MSI Afterburner Overclocking Utility</b><br>
- Support 2D/3D customized profile.<br>
- Support SLI & CrossFireX mode.<br>
<br>
<b>Native HDMI Output</b><br>
- Supports both 1080P HD movie playback and 7.1 Channel audio transmissions.<br>
<br>
<b>Low Profile Design</b><br>
- Extra Large heatsink for the best heat dissipation and zero db noise.<br>
- Work perfect with slim or smaller system.<br>
</p>
<font size="3"><b>Specifications</b></font></p>
- Low Profile Passive Silent Cooling design <br>
- Core Clock: 650MHz<br>
- Memory: 1024MB GDDR3<br>
- Memory Interface: 64-Bit<br>
- Memory Clock: 1066MHz (Effective)<br>
- Processing Cores: 80<br>
- Bus Type: PCI-Express 2.1<br>
- Display Connectors: 1 VGA, 1 Dual-Link DVI-I & 1 HDMI<br>
- HDCP Capable<br>
- ATI Avivo HD<br>
- ATI Stream Technology<br>
- Excellent for Media playback<br>
- Support DXVA & surround sound over HDMI<br>
Was [£25.99] Inc. VAT
Only £19.99 inc VAT.
ORDER NOW
Guys I don't have to tell you this but this pricing is mental, it is actually below trade pricing, so this pricing is the best in the UK by far, no one can come even close to this.
Also remember all the free games you get too!!!! :D :D :D
THIS PRICING ENDS TOMORROW AT 5PM, SO ORDER NOW TO AVOID DISSAPOINTMENT!!
Gibbo,
Can you confirm that if I was to buy one of these AMD cards, that I'd get the 3 free games and the free Dirt Showdown too as its over £25?
there were reports of issues with the asus 7950 on release:
http://www.behardware.com/news/12153/asus-hd-7950-directcu-ii-fault-report.html
I read on another site it said that asus then released version 2 of these cards where the issue is fixed. Is this a version 2 card?
I'd avoid any potential v1 of that card and just get the Windforce 7950 instead. Same clocks, same 3 games for free included, cooler is just as good if not better and it only takes up 2 slots. I've had the same cooler before and it was very quiet with great temps.
Getting the Windforce 7950 tomorrow. :)
I mean't that the graphics card will be over £25 so you get Dirt Showdown for free until 5pm tomorrow ;):)
ok.
downloading starcraft 2 at the moment,hope my integrated hd4000 will be able to cut through it if not I'm going to need dedicated gpu.
i want to get gtx660 or gtx670,depends how they'll price the first one and how good they'll perform.
hd7xxx series seems to have few more problems with the drivers,so I'd rather bought nvidia card.
Gibbo,
Where is the '3 for free' offer? I can see that there's two games free with the 7850/7870's, but can't see anything beyond that?
I'm just about to order a 7870 and don't want to miss out :)
EDIT: Just found it. It's only the 79** series cards that have this. It's basically the same offer at the 78** cards but has 'Deus Ex Human Revolution' as well. Tthis is the link to the offer:
http://www.overclockers.co.uk/showproduct.php?prodid=GX-000-AM
I would prefer the asus though, that cooler will be so quiet. Can anyone from ocuk comment on whether it is an updated version of the card?
The drivers for the HD7xxx have been rock solid for me. No problems at all. Now I've seen this offer I'm seriously considering going Crossfire.
people reported problems with hd7850,hd7870, gigabyte though seems have a lot of a problem with hd7850,(black screen) msi,asus as well.
sapphire seems to be all right
Can anyone comment on the noise under load for the Gigabyte windforce or VTX X-Edition 7970's ? I have a Twin Frozr 570, under load it's reasonably quiet and I couldn't move to anything louder. I'm thinking of moving to AMD as their cards are a better match for 3D on my S27A950 monitor
