I have built a server and I am looking for some hard disks to fill it.
I recently built another similar server with 6x 2TB Western Digital WD20EARS, but there must be better HDD's out now for speed, efficiency, reliability, cost?
I was thinking the Seagate 3TB ST3000DM001 7200rpm/64MB Cache, which I have seen for around £115 a disk.
The server (if this info is helpful):
Supermicro X8SIL-F:, Xeon X3450, 32Gb ECC RDIMM
The case can fit 9 standard 3.5" HDD + I have installed a Vertex 3 SSD (60Gb) to use as cache in ZFS
RAID controller is a IBM M1015 flashed to be an LSI 9240-8i
It has 8 ports which I have passed through ESXi 5 to OI+Napp-it ZFS RAID10 as an NFS datastore. Unfortunately, I may have to use one port for the cache SSD? leaving 7 for the ZFS Raid, I'd hope to find a way around this to have all 8 ports for storage, but thats another problem. I also hope there are no issues with me exceeding 2TB per disk.
The mainboard ports can be used as datastores but not passed through, I need to look into this.
Thank you for any advice you can offer
