I would say that the dual core chip is holding him back in some instances but as has been said Source is still a DX9 based engine and is very much a CPU restricted engine. The 670 may not be as efficient at DX9 as your previous card either.
the heaven score is seriously low too, at 1080p with those settings I get 1900 on a single 670, 1680x1050 should be well over 2000 for a 670
dual core processor FTL
Play a game that will test the gpu, such as BF3.
The Heaven benchmark score looks low. I thought Heaven was purely a GPU benchmark and CPU made little, if any difference?
For reference I run 3570k at stock with a GTX 670 and at 1680x1050 I get 2017
mines an MSI OC reference design one. It doesn't have a major overclock, not enough to be 300 points higher I would think?
indeed its not, see my post #24![]()
I'm going to make the wild assumption many of you newly registered folk are quite young.
Most of you will not remember the days of going from a Voodoo2 to a GeForce 1. Even on the same processor (Celeron 300 / Pentium II), the performance difference was STAGGERING. This was true innovation.
'Play modern games' or 'get an i7 and overclock it to 5.5GHz' is missing the point somewhat.
bf3 runs a lot better on quad cores so he will be bottlenecked with his dual core cpu.
You wouldn't buy a Ferrari with a Metro engine in it.
