Usual mixture of acknowledgement/disbelief, no surprise there.
2Gb is more than enough@1080p so far, as I said turn the settings down if/when needed.
I(unknowingly) took it over my gpus vram limit, in all likelihood,
I shall tweak the mods to reduce the usage back under 2Gb as I'm not convinced I'm keeping the 7970.
A mixture of unoptimised/large textures is what's taking it above 2Gb, it doesn't require anywhere near that amount of vram when you install vanilla Skyrim so it's in the users hands to where the vram use totals out.
I can get 2GB of VRAM usage on my GTX680 playing Minecraft.
You should put up a thread with screens and inform others of your findings.
It ain't.
If all you play is Skyrim heavily modded and you're looney or money isn't an object then sure pay the extra.
If you're getting into a scenario of paying more than the games worth in hardware just for that game (and the game is modded to the ****) then that just isn't worth it in my eyes.
As a factual statement which is what Tommy's research is then it is extremely useful to know.
+1
You would have to be mental if you were to chuck a perfectly good 2Gb 67/80 or 69 series CrossFire etc, away just for 1 game.
The only way whatsoever could I advise anyone looking for an
upgrade to get a 4Gb 67/80@1080p over a 2Gb version, would be if you fall into the bracket of a user that only upgrades every 2-3years, even at that, you might not get your moneys worth out of the extra 2Gb.
You don't get vanilla titles that have the size of textures that's sitting in my Skyrim, period.
A mixture of unoptimised/large textures is the cause of why it's going above 2Gb, it doesn't require anywhere near that amount of vram when you install vanilla Skyrim so it's in the users hands to where the vram use totals out.
As andy pointed out
, the aim of the post was to inform that you can breach 2Gb in Skyrim, remember folks the thread is called:
Skyrim breached 2Gb vram@1080p
Not:
Chuck your 2Gb gpu in the bin because it runs out of vram@1080p
