The whole point in asking was so i don't have to waste time doing that as someone who has already bought cables with the correct up/down configuration that i'm asking for can give me the batch number of the cable.
they will all bend the same wat as the metal latch must fit on one side of the connector
further question on a similar topic....if you have a regular SATA III cable and put the right angle connection on the mobo SATA III port and the straight connector to the SSD, will it make any difference at all??
I only ask because the motherboard instructions tell you to put the right angled connector on the Drive / peripheral not the montherboard ?
