- 16 Jun 2010
- Manchester
Hey guys how do I stop it frothing in the res? Also seem to be lots of micro bubbles in the loop that I can't seem to get rid of.
that + the noise of the spinning impeller + the noise of the water = i am getting rid of mine![]()
Why is yours bad ?
that looks stunning. I'm also borrowing you're loop design for my build.
Is there any gap between top of mobo and fixed bay plate?? And do you have any fans in front of lower rad.
Distance between underside of top rad to top edge of motherboard and the fixed plate in the drive bay, which i think is above your fan controller.
Is it the bitfenix recon? If so how is it?
Have you tried switching the front fan configuration to have the SPs pushing into the rad and the AFs pulling into the case?
I would've though that would be better. Not that you'd notice temp-wise I guess.. May help force more air into the case though.
