Owners of Gigabyte X79 boards...
25 Jun 2011
Aberdeen
Hi folks :)
Still doing some fine tuning on my setup, but I'm getting stuck with GB's LLC options on the UD7, I presume the settings are the same/similar on the whole X79 range (UD3/5/7/G1).
All the videos, guides I see show the LLC adjust showing as a percentage, from 0% to 100%. However when I adjust my LLC settings all I get is "Auto, Standard, Normal, Medium, High, Turbo & Extreme" none of which do anything but make vdrop even worse than it already is, I've already tried 3 bios revisions, F11K, F10 & F9, all the same.
Am I missing something obvious? It does show a percentage, but it never changes, looks something like:
[vCore Load Line Calibration] - - [+60%] - - [Auto]- The latter box being the only one that will adjust.
All other LLC settings adjust as they should, with a percentage just not the vcore setting :confused:
i think you can only use one at a time llc or dvid(cpu offset) not both together,z77 lets you use both together on gigabyte boards
idk if thats what you meant?
Nope, dvid is disabled running a straight core voltage, what I'm asking is what other giga boards in the range show under llc, the videos and pictures I see for the ud7 show an adjustable percentage llc, I have no such options, as a result my vcore is dropping by over 0.040v :(
Will have a look tonight wazza, I'll grab some screens of what it shows and what it apparently should look like too :)
Damn, what bios version is that on?
Going to try F7 & F8 tonight I think.
I'll also directly measure the vcore from the motherboard with a multimeter, check it's not a reporting error.
I was on f11k (I see f11m is now available for the ud7). I need to double check what bios version sends these boards up in smoke.
none... the board that blew was because the bios allowed the user to set extreme voltages which then blew the board - it was operator error
the newer bioses are locked to much lower voltages to prevent this
I have a UD3 and LLC settings do nothing to help - I just account for the drop by setting slightly higher than desired... the drop is very predictable and occurs solidly everytime the CPU gets loaded so it doesn't bother me too much
Some Gigabyte boards seem to have real problems with v-droop, it's mainly why I still buy Asus.
Gigabyte had trouble with their VRM's settings on fire when X79 was first released so this weak LLC implementation may be a result of that.
jesus, read what I wrote above
the ONE case of VRMs setting on fire was because the USER WAS AN UTTER IDIOT who went in to the bios and put all the voltages on full
the result of which is that gigabyte have massively reduced the OC potential on their boards by limiting voltages to settings that they know for sure won't allow this to happen
that's also a little unfair, as my last mobo was an Asus and that also suffered from massive vdrop to the point that there was a pencil mod you could do to help it back up a bit
Thats good to know, I must admit I was guilty of only reading the headlines along the lines of "X79-UD7 bursts into flame on bios Fxx" without digging any further into it, so thanks for easing my mind on that front.
I won't be doing anything overly drastic with regards to voltages, I don't have the memory to mess around with the IMC voltage or the smarts to fiddle with the PLL. Plus the VRM's are going under water soon.
Going to drop it down to F2 (stock bios) and update and see at what point the LLC becomes a crippled nonsense option.
Ok so I can't drop from a retail bios down versions, I think I can however drop from a beta version down, so going to have to go F9>F11M>F2
Edit: Maybe not, currently impossible for me to drop any lower than F9.
Quite a let down to have such bad vdroop on a high end motherboard, guess I'll just have to try navigate around it, the drop is floating between 0.038 - 0.040v regardless of LLC setting so I'll just have to calculate from that.
The Vdroop on Gigabyte board is some of the worst Vdroop I have seen in recent years, it REALLY IS POOR, I was a gigabyte fan, but my next board is not going to be Gigabyte.
My UD3, set the volts to 1.4, it Vdroops under loads to 1.28, that is frankly disgusting.
This explains why I needed to set 1.4v to get 4.75ghz because really it's doing a little over 1.3v under load lol.
Intel spec is 60% or 0.60 ohms I think, the least droop I've managed at all is setting llc to extreme 1.45v giving load voltage of 1.424v.
Having bios issues now too cmos checksum keeps failing. Tempted to cut my losses and get a RIVE tbh.
Th p8z68 I had suffered from no droop at all, 1.38v gave me 1.38v
