Road Cycling Essentials
Status
Not open for further replies.
I'v not really had any problems patching tubes. Are you leaving them long enough for the glue to properly set?
I usually leave something heavy holding the path onto the tube for a few hours at least.
Anyone got a link to any easy to follow bike setup info? after the weekend cycle my knees were killing me, i recently heightened my seat a little and it was more comfy by my knees hurt more than the did before, but when it was lower it was uncomfortable :(
Can anyone recommend a puncture repair kit suitable for high psi? I bought some self sticking ones and they are rubbish, even when I use the old school sandpaper, glue chalk and patch they still don't stick.
The biggest mistake people make when using the patching kits is sticking the patch on the tube as soon as the they have applied the vulcanising solution. You have to wait till it appears dry, usually around 30s to a minute and don't lift after you have stuck it down to see if it has stuck.
Apologies if you were using this technique but I had the same problem as you till I bothered to read the instructions that came with the kit :D (I use 120psi on my rear wheel and 100 on the front)
Well I'd be broke if I bought a new tube every time I got a puncture. Wilkinson's self adhesive ones seem to work fine for me, but I've just got another puncture, so I'm hoping it's not the patch that has let go. I did ride over a load of glass (and I had no choice, before someone picks me up on it :rolleyes:), so it was probably that. I've also been ok with the Wilkinson's glue and patch kits, but the glue is definitely better in the Weldtite kits and the patch grabs on a lot better at first.
I've ridden over 1200 miles on my commute without a single puncture, Continental Sport Contact 28C, maybe thats why I'd just replace rather than repair!
My Continetal GP4000's haven't had a puncture yet either, but are only a few hundred miles old, touch wood they keep perfoming as well as the commuter tyres!
I've had well over 10 punctures in the last year. There is a lot of crap on my roads, particularly when you cross the council border into Croydon.
Sounds like you need new tyres, or at least check you've got your existing ones at the right pressure. I've had no punctures in the past 8 months of riding around Croydon! ;)
Just popped out during lunch to watch some of the triathlon.
Jonny Brownlee
Yea you definitely get a lot of bang for your bucks with a Boardman, my mates have got Giant and Trek, i tell you, they have had numerous problems over the past year with them, me on the Boardman, worst ive had is 2 punctures :D
Status
