The longer lifespan of IB comes from the extra features it provides, not the performance difference.
It's also much more voltage tolerant than Sandy Bridge. Something which may affect lifespan in heavily overclocked CPUs.
True. If anything I should have explained my statement better! The features it gives (namely pci 3.0) are probably the bigger factors in what will keep IB going longer so to speak. Since CPU's bottleneck GPU's faster than anything else.
Seriously man, both chips are awesome but why not go with the new IB? I would.
OK i have one of the 1st SB 2500k. (I have OC to 4.8 on Asrock Falal1y P67.rev B3. Didn't go higher. Pointless. Only 4.4 on Asus P67 Deluxe.Max.1st rev.) My Son has the Asus now with Intel Celeron G530 2.40GHz. I have a Asrock Extreme 6 Z77. I was thinking of giving him my SB and getting a 3570K or 3770K.
Main uses would be Gaming.
I also have a canon 7D and while be starting to use video.
GPU is 7950 880mhz.
Win 7 is on a 256gb Sam 830 and I have 9 hdds in my box plus 2 external drives .
Would I NOTICE any benefits from the IB chips. Apart from encoding?
Can some one provide a link convincing me to upgrade?
Cheers guys.
GPU is 7950 880mhz.
Cheers guys.
Debatable. The benchmarks I've seen suggest Ivy is 5-10% faster than Sandy, at the same clock rate. So 4.7 GHz SB should be as fast or faster than 4.3GHz IB.wouldn't a 4.3ghz ivy still beat a 4.7ghz sandy ?
Personally would get the 3570k for the PCI-E 3.0, seem's pointless going for a 2500k given the price difference. I wouldn't upgrade from a 2500k but buying new I'd get the 3750k and wouldn't think twice about it.
For crap Cooling IVY
For good Cooling Sandy
I had both on my water cooling. I was not hapy with clocks of IVY what so ever 4.5 was max i could get out of it with 93c max in ibt. On sandy 5ghz i get 86c in ibt. Same cooling same liquid ultra thermal compound same day.
Who cares about few Wats anyway when your blowing 160f for cpu ?? Better off getting energy saving bulbs all around the house or **** like that.
If you dont need anything more than 4.3-4.4 i would go for ivy with 20f cooler.
