Hi,
Just bought an OCZ Agility 3 240GB SSD from OCUK, installed it sunday. Has all been working fine until about an hour ago when I was using IE and all of a sudden a blue screen of death popped up saying there had been an error etc.. after about 30 seconds the computer restarted iself, but Windows failed to load.
Went into BIOS... SATA1 (where SSD is connected).. nothing recognised?! Tried restarting but it just said Windows could not start as a device was not found (the SSD I'm guessing). Told me to insert Windows 7 disc, restart and go into recovery mode. That did nothing, Windows repair on the cd couldn't find the SSD either, only the old HDD.
I turned the machine off, unplugged the SSD from SATA1 and tried it in SATA5, booted up and it worked fine for a few minutes. Windows then froze with programs just saying Not Responding, nothing working, not even task manager, so I had to hit the power button to restart. Same problem, SSD not recognised on SATA5. Tried SATA1 port again, nothing, tried other SATA ports and different cables... nothing.
Tried it with and with out HDD connected, didn't make a difference. Its not the SATA ports on the mobo as they work with my old HDD okay.
So is my new SSD dying? Did that first blue screen crash cause some corruption which is now causing these problems? In the side of the SSD I can see a little green light.
Thanks,
Pete
Thanks,
Pete
