Why does my sig keep on getting edited?
22 Aug 2003
What is the signature for? [edit your profile]
You may use a signature (commonly used in email messages) in your posts. You can specify in your profile a signature to use at the bottom of your posts. When you post, there is an option to use your signature. A signature may contain one or more images but they must fit within a box with maximum dimensions of 400 x 75 pixels (width x height) and with a maximum (combined) file size of 20k. Images containing mostly very large words or animated .gifs will not be permitted. You may also add 1 consecutive lines of normal or smaller text directly above or underneath the image with no spaces inbetween image and text. If no images are used then up to 4 consecutive lines of normal or smaller text is permitted. Do not pad out your text lines with blanks lines. A line of text is defined as having a maximum length of 400 pixels. If you want to turn the signature off in the future, you can come back and edit your post. If you have specified a signature in your profile, the box will be automatically ticked for you.
The forum Dons/Admins reserve the right to judge individual signatures, particularly those deemed to contain material of an adult or offensive nature. If the Dons/Admins think the signature is unsuitable for a family orientated forum, then it will be removed. If the user then replaces it without making changes, they will be suspended.
I emailed the mods using the http://forums.overclockers.co.uk/sendmessage.php button but no one has replied, but I keep on getting the daft message below.
I had a link to my blog (non competitive) and after reading the FAQ I was worried that my blog had been hijacked and it contained. Can anyone help?
If this is the case then thanks for clarifying but am I reading the wrong FAQ?
Seems like they've generically linked you to the sig faq when the rule it was being removed for is this one:
No promotion of business interests
You may not promote any website or business you have a financial or other interest in, or use the popularity of this community to help build one of your own. The forums are here to allow people to freely share knowledge, not provide them with personal financial gain, or free advertising.
Why would you?
Remove it or put it there?
So do I have to remove the link to my youtube videos?
Maybe a mod will link to the correct FAQ is one does exist?
Do you make money from advertising of your videos (or do you own youtube)?
My blog was intended to be giving away advice but this is probably lost on the average volunteer on here :rolleyes:
