I've gone up to a large set of rings up front as I couldn't get a replacement 50T, so got a new set of cranks and all and have gone to 39/52.
As a knock on of this I had to adjust the front mech slightly to take into account the larger chain ring. As it is bolt on it just needed moving up slightly, slight altering of the tension on the cable and then a readjustment of the high/low limit screws to set it right. A bit of oil and working the mechanism up/down helped improve the movement too.
It shifts as it should now and the chain doesn't foul.
The only question I have is that the red marker in the shifter isn't equal when you move it side to side. It sits on the white line as it used to when in the big ring, but dropping down to the smaller one, it moves a lot further over. I can't see this being a problem at all, but I couldn't work out how you adjusted this?
Will give it a test after work tomorrow and give my legs a workout!
And a rant for another day is, why do manufacturers make things up as they go along. When fitting the cranks, the dust seal on the LHS looked to be a huge Torx bit, but turned out to have 1 extra tooth on it, requiring a special Shimano only tool. A 12mm allen head fitted instead with a bit of a wiggle, since it was only being done up to 1.5nm anyway (sweet FA!).... why not just make it a 12mm allen or a standard Torx! Yet elsewhere normal allen bolts are used. Allowing me to use my Teng 1/4" to torque the crank arm bolts correctly, torque range 12-14nm so that would be 13nm then
