Hi there
Its a long overdue visit, but I am at COG for the day to have some new Porsche suspension goodies fitted along with a full GEO setup.
Cars current GEO is well a bit all over, due to wear and tear on suspension components and well use and trackdays.
So far we've diagnosed in the suspension overall the following needs to be done and is being done as I speak:-
Front suspension bump stops - These more or less destroyed, no doubt due to trackday use (heavy braking), thankfully the dampers are fine, no leaks or damage.
Front top mounts - They are nearly gone and with more front camber they will be destroyed, so being changed to the latest Porsche generation models.
Front Springs/Struts - Filled with stone, gravel, tarmec, no doubt due to council treating the roads by just putting loose chippings down. Does your springs no favours as the drainage hole block, causing drains not to work and springs sit in water making them rust and eventually snap. So all road debris removed, cleaned and all re-greased.
I shall post up what the GEO setting were and what the new settings will be end of the day. But with all these new fresh parts in can't wait to drive it again.
Here is a picture of it on the ramps at COG:-
Many places can do a GEO, but so many places will just take your car and well put a GEO on it. Whats the point in this if parts of your suspension are worn or broken, the GEO will be lost the moment you drive down the road.
Some pictures of the things were finding along the way:-
Think Bumpstops have had it, next to new ones to show the difference
Springs cleaned, all stone chipps got out so drainage holes unblocked and all cleaned up and re-greased
Top mounts de-laminating, see the rubber seperating - NOT GOOD!
