Deadlifts tonight, week 2 of ortmeyer.
warm up
180 4x4
205 x 2
230 x 2
180 x at least 8 reps.
Doesn't sound much but it's a killer!
What days you doing currently on Wendler? Im doing the typical Mon/Tue/Thur/Fri.
Ended up at Physio today due to spinal issues and it just looks like a very stiff spine at my lower half (spent 10 minutes with him pressing on my spine until there was some give in it as it wouldnt move). Also got some more mobility exercises to add to my neverending list
Anyway, Deadlifts tomorrow! got a 5+ set of 140kg for my first week in cycle 3![]()
You suffer from Patellofemoral Pain? Pain in and around the knee cap when bending the knee?
If so it's because the bones rubbing below or agains ths knee cap. Nasty stuff, if you're dead set on the leg press do be careful for your knees and stay away from leg extensions, they're terrible for it.
Also for pure mass building 5-8 is very low. 8 is the minimum really and when it comes to the leg press you want at least 12-15 reps per set.
Personally I do 12-15 for legs for 5 sets and for upperbody I work at 10-12 reps.
For good strength gains 5-6 reps are very good, in sets of 3.
Good newsWhat days you doing currently on Wendler? Im doing the typical Mon/Tue/Thur/Fri.
No no, that sounds horrible enoughDeadlifts tonight, week 2 of ortmeyer.
warm up
180 4x4
205 x 2
230 x 2
This is extremely confused. Why are you only doing 1-2 proper exercises per day? Your rep ranges are off too. The article you posted is correct, but you aren't being forced to pick one rep range... 18 rep cable pull downs??Day 1:
Bench Press5x5
Barbel Curls 5x5
Plank
Power walk home from gym 30mins
Dayoff: 30 mins swimming laps
Day3:
Military Press 5x5
Cable Pull Downs 3x18 Super Set
Crunches 30
Day5:
Leg Press 3x10
Pull Up's 3x10
Leg Raises
Return to Day 1 etc etc etc
Very good routine for getting stronger... hope it will be enough for me to lose some fat as well...
Considering my diet is cleaned up and I was a couch potatoe before, surely this is better than before..
This is better.Day 1:
Bench Press5x5
Incline DB bench 3x8
DB Fly 3x12
Barbel Curls 3x10
Plank
Day3:
Pull Up's 5x5 - add weight
DB row 4x10
Tricep isolation exercise 3x10
Face pulls 3x10
Leg Raises
Day5:
Leg Press 4x12
Military Press 5x5
Reverse lunge 3x8/Step ups 3x10
Lateral raises 3x10
Rear delt fly 3x10
Good news
Why have you arranged your back work like that? Where is your tricep isolation?
This is better.
To be honest though, you better off just doing any programme than chopping and changing all the time.
If you're still looking, these are extremely good: http://greatist.com/gwod/
If they suggest squat, just do leg press.
Oh, you mean PUSH downs. By definition, any pulling movement is going to involve your back and not your triceps, so "pull downs" would refer to lat pull downs. Also, "TBar" is normally used to describe a piece of equipment used for rowing movements, just to avoid further confusion.The tricep isolation im doing is a super set of 6 cable pull downs followed by palms up and palms down with the Tbar.
For back Im just doing Pull ups.
The routine is split up in to Chest/Bicep, Shoulder/Tricep and Legs & Back
You'd certainly get bicep activation on pulling movements, iirc I've read that you get more bicep activation on chins than anything else.
I feel like a bit of a douche for nit picking terminology, but I need all the help I can get to avoid being confused![]()
