Leaking pump!
1 Jan 2012
Scottish Borders - UK
Got my d5 vario today- everything set up, leak testing my build and wtf? LOts of water coming out the back end of the pump!!
I pulled it to the side of the case and the back section was loose. Tightened it - still the odd drip - tightened it like he-man and now it seems fine.
Is this a common thing? For pumps to come with the rear section loose??! I saw a huge pile of water and was like wtf??!
Did you buy an ocuk tech lab d5 complete with top?
If so this may be why, both me and cleee have bought these and bboth have leaked from the pump clamp plate being slightly too slack.
No mate. Was just a pump without top.
It may have been a better option to check the o-ring, but when your loop is full of water and you notice something is slack - the first thing you do is tighten! Lol
All seems ok now after a night of leak testing.
I think the tech lab tops are being left slack as the first one the sent me was too tight and cracked the top :o
Glad to hear you sorted the leak :)
