- 27 Dec 2005
- Bristol
Ok great. I do have a hacksaw but I don't think that'll be up to the task but I'll give it a go. I need to go to B&Q soon anyway so I'll pick up one for metal.
I have a question for you guys about bike weight.
I weighed my bike last night, it's just under 10kg unloaded (well, two bottle holders on it).
I weigh about 80kg. Now, I've read a few bike reviews, you can spend 2k and get a 7kg bike. In the grand scheme of things, taking into account up to 1.5kg of water, a bag with tools and food in it, would I even notice losing 3kg off the bike?
This is obviously not taking into account more expensive bike components, which I assume offer a higher degree of efficiency etc.
I suppose it works better for someone who has already gotten down to their minimum weight, carrys a light load and takes part in races etc.
You can't really take in to account the tools and drinks as you would have had them on a heavier bike making that bike even heavier.
IMO I'd rather have a light, high quality bike, then if I don't perform I can't blame the bike.
I can't wait to get a newer bike! Cycling on a steel framed 25 year old racer ftl.
Canyon Ultimate CF 9.0
The 11-28 on the compact will give you better gear ratios for going downhill than a 12-25 on a double.
*You can pay a bit extra for the non-default cassette if you want, so you could have the 11-28 on a double chainset.
I didn't say otherwise did I?
The compact will give you the gearing closer to that of the lower gearing on a triple. Good if you need a granny gearing but you will run out of pedal downhill.
