Hi guys I was just wondering what I should get for gaming the 965be or the 960t for my gaming pc.
I can get them for about the same price so just whats better for gaming not bothered about anything else and also my motherboard is a m4n98tdevo
Thanks for the replies guys I was unsure that it was better because the clock speed was lower.
After listening to your recommendation I will definetely get the 960t.
Dirty ganker,
I am currently using:
8gb 1600mhz kingston ram
m4n98td evo motherboard
amd 6790 (replacing tonight)
athlon 455 (replacing tonight)
I can't afford to move over to the i5 as I only have £300 to spend max and £100 will be going on processor and £200 on graphics.
You don't need to get an i5, even an i3 is comparible.
I have the same processor (for another 2 or 3 months anyway) and can do 3.5ghz @ 6core - CPU/Nb is currently 2400.
I'll be buying water cooling next week and will see if I can hit 4ghz stable...Then it's Ivy Bridge for me.
there is an official AMD overclocking guide. http://sites.amd.com/us/Documents/AMD_Dragon_AM3_AM2_Performance_Tuning_Guide.pdf
Dolks guide is okay but the AMD was so much easier to use.
