come on u two, enough now. you both suggested things. let's leave at that
You're right there could be a whole plethora of issues.
However, it was fine before on the old drivers and now it's not on these ones. I hope you don't deal with your clients in such over complicating ways otherwise you may find yourself out of business if they get wind of it!
This isn't about me no matter how much you turn it into some kind of odd personal crusade.
p.s. your grammar is appalling.
Yes it was fine with the old drivers and now its not, its upto him if he want to get the to bottom of it or not
*snip*
Bye.
He has, the drivers! And he's resolved it!
Good night mate.
A couple of questions I did try these but I am having a few bf3 freezes not sure weathers it's this driver.
Anyway I have gone back to the 12.7 beta, my question is in after burner is it meant to say 9.14.10.0924 catalyst 11.12? I'm not using CCC just using the drivers.
Thanks
How about the CPU ?
Yeah I will give that a go, what I'm going to do is try the betas again over the next few days and if it still does it I will go stock CPU to see.
Regards
Going back to previous drivers where presumably the issue is not there... Otherwise why roll back?
Thought you were going?![]()
with 12.4 i get between 95-99% on all 3 gpu's.. with 12.6 or higher i only get between 65-85% on all 3 gpu's + less fps
anyone else having annoying problems installing the 12.8s? after the installation finishes, it doesn't return my screen, so i had to vnc to it to restart
1080pAt what res? It's known that the last couple of releases are geared towards two cards rather than 3 or 4. Anyone I've seen at 1080p has never gotten 95% scaling on 3 cards in BF3 MP.
1080p
but even at 3840x1080 it doesn't go as high as 95-99% with 12.6 or higher
Motherboard
Asus P8P67
CPU
I5 2500k @ 4.7Ghz @1.38
Graphics
MSI 7970 OC @1200/1675 1.168V
Memory
16GIG Kingston DDR3 1600mhz
Cooling Solution
CVorsair H60
Display
28" LG HD LCD TV @1080p
Soundcard & Speakers
Logitech G35
Hard-Drives
Intel 330+320 SSD
Optical Drives
DVD ROM+RW
Power Supply
XFX Black Edition 750W
Case
Corsair 600T
Input Devices
Razor Deathadder Left Handed Mouse + Logitech G11 Keyboard
Operating System
Windows 7 64
These drivers are god like in bf3. 7970 @1200core 1700memory 1080p full ultra @4xaa barely drops below 60fps vsync. Loving it AMD.
Motherboard
asus rampage 2 extreme
CPU
920 @ 4.7 ghz
Graphics
xfx hd 7970 BE crossfire @1350/1800
Memory
12 gig corsair dominator 1600 mhz
Cooling Solution
thermal chill 120.3/feser 360,dual 655 pumps with ek top,ek hf/w blue top/ek , EK 6990 block
Display
3007
x-fi forte + logitech z-5500
Hard-Drives
3 ssd's + 2 tb black
Power Supply
xfx 1250 watt black edition
Case
p180
Input Devices
logitech g510, g700 , logitech driving force gt , logitech 270 web cam
Operating System
w7 64 bit
Extra Info
http://s550.photobucket.com/albums/ii415/steve_hen/steveos rig/
yes i agree these drivers are god like ! i gained 10-15 fps , and my min fps went up 10-15 fps also in bf3 at (1600p ultra/4x aa)
and for some reason my max overclocks have increased a lot ?? i'm hoping to be able to hit 1500/1900 next time i try 1450/1875 is stable
i though the june26 12.7 was awesome , the 12.8 is even better
1080p
.You're right there could be a whole plethora of issues.
However, it was fine before on the old drivers and now it's not on these ones. I hope you don't deal with your clients in such over complicating ways otherwise you may find yourself out of business if they get wind of it! It'd be like those plumbers who charge for a whole rework of the pipes when the tap is broken.
This isn't about me no matter how much you try to turn it into some kind of odd personal crusade.
Everything I say you completey ignore and you proceed to argue with yourself about something I haven't said.
Well I'll be sending back my GTX670 tomorrow and ordering my 7970. BF3 is the main game I'm playing at the moment but from other titles I can see the want for the AMD card.
What driver is best for BF3 for the 7970?. It would be handy for some people's input on this as that will be the first game I'll be trying. I just hope I'm going to be happy with the card and not send it back to get the GTX 670 again as that's £20 spent on postage for sending back the 2 cards if I do switch back. For the £300+ I'm spending I'm not worried at spending £10-£20 to make the right choice.
I will be ignored yet you still took effort to post all that. OK mate![]()
If you care to look through my previous posts you will get a proper picture rather than extrapolating one post and drawing some strange conclusion from that.
