Thats quiet bad lol.
If its not broke dnt fix it.
As far as ssd bench use atto or as ssd
you could see if there was a new bios update but appart from that not sure.
If that was mine i would take the cooler off and replace it with a backplated cooler to hopefully make the board abit more straight.
The mobo hadn't been taken out of the case it was in previously for about 4 years, I noticed the mobo screws weren't in the stand-offs very well, maybe this could have caused the warping?
I would say it was the cooler causing the warping. The push pins pull inwards without ANY support for the motherboard.
Its not so bad on 1155 as they have some form of a backplate.
Do you think it'd be safe to remove the cooler to give it a proper clean or would it risk cracking?
Ok got a cheap GTX260 lined up for some very light gaming.
Will my CPU (E6750 @ Stock) be a bottleneck though?
Cheers
