I am incredibly tempted by the 7850 for £167.99. Might have to say goodbye to my GTX 295.
http://www.overclockers.co.uk/showproduct.php?prodid=GX-157-MS
The price has gone back up on that one. Might want to look at the Sapphire or MSI cards.
I can't decide for a build I am doing for someone. 7850, 7870 or 7950. From what I can see, the difference between 7870 to 7950 is not that much? Also, the 7850 appeas the same as 7870 but just typically clocked lower at stock? Is the best buy here to get the best 7850 you can and overclock?
http://www.overclockers.co.uk/showproduct.php?prodid=gx-157-ms
I wouldn't go lower than the 7950 because of the vram.
Of course if you plan on upgrading often or don't plan on using hi-res texture mods/packs in things like Skyrim, 2gb should be ok.
Surely 2gb of VRAM is enough for most modern games at high settings?
Recommendation please. Currently have a 4870 which needs replacing. Which of these cards should I go for? Looking to spend the least possible, but would still like a decent jump in performance from what I have if possible.
Propeller Blade on Twin Frozr III
- The special blade design generates 20% more airflow than traditional design.
- 10C cooler & 13.7dB quieter than reference design!!!
Twin Frozr IV cooler with Dust Removal technology
- Provides 22°C Cooler and 11dB quieter operation than reference product
- cooler removes dust build up every time it is switched on to keep cooling performance optimal
would i still be able to get at least £100 for my 560ti do you guys reckon? if so am definitely upgrading to a 7870 / 7950
I went for the last one. Apparently the IV cooler is a improvement over the III, and for an extra £8 I thought it was worthwhile.
This is what it says on the product description.
Still waiting for a response to this please.
