- 26 Dec 2005
- Paisley
If I install it, and do the updates, can I copy the folder across to my home PC?
Brilliant thanks.
How easy is it to get into? Do you have to read the manual or does it teach you as you go along quite well?
haha, I was lucky to find that event last night too![]()
Brilliant thanks.
Brilliant thanks.
You'll need to take a 5 day training course, after which there are two written exams, only then will you be able to play the game
But that's not intentional is it? I noticed this in the beta and they still didn't fix it, there's simply not enough content to level with a good flow and I always find myself 2 levels behind of a lot of stuff, basically forcing you to grind an event.
How is the game running on people's rigs? played swtor at launch and that ran badly tbh
3 hours in i'm at level 5.
it seems more 'grindey' than I was led to believe..
I love how you're not restricted in the way you choose to level though. Follow your personal story through each are? No problem. Run around 100%ing all noob areas? No problem. Craft? No problem. The fact that you can WvW at any level has taken massive pressure off needing to rush and play catch up. I just hope there is longevity in the game for those who play hardcore so the game doesn't get ruined by them complaining about lack of endgame.
