Its double weapon xp all week. I've been having fun levelling up some different guns now I've reached 20th prestiege.
I levelled the Striker up to damage and range, not sure which is best but I assume its the best shotty, especially if the first shot doesnt kill.
Regarding Domination, no one really seems to want to play the objective, even less so during school hols. Having said that I played ground war last night and it wasnt that much of a struggle to win the domination games and have a mad kill fest.
Which is the best sniper to use? MSR? Havent used many apart from L118a.
The striker is indeed the best shotgun even since it was nerfed a few months ago (it used to be even more horrendously OP). You generally want to put damage on it, the reasons being
1) if you start with damage you get range proficiency at 8 kills with specialist anywa, however if you start with range you don't get damage
2) striker pellet damage doesn't have that bad a drop off at it's maximum range. The pellets still do 15 whereas all the other shotguns except the KSG do only 5.
Adding damage will make you kill in 3 pellets close range (down from 4) and 5 at max range (down from 7) which is a huge deal. The striker fires 6 pellets. If you have range on, the difference within it's standard range is very negligible and will be at most 1 more shot. It'll let you hit people at further max range however at that kind of range you'll be doing only 15 damage and likely only hitting with 0-2 pellets meaning you'll be dead before you can fire enough shots to kill them.
The best sniper is the MSR although the L118a is extremely close. Their damage, fire rate, run speed, recoil and multipliers are the same so just use whichever you prefer. The MSR has very slightly faster raise and drop time so it's technically better but realistically the difference will probably be like 1 kill in 10,000 if that. The Barrett is good too and has a larger 1 shot kill area (includes lower chest) however you run slow. It can be fun running around with steady aim and speed though and using it like a shotgun cos the fire rate is ridiculous.
Everyone just farms kills in domination because it's so easy to get MOABs and high killstreaks and ZOMFG QUAD HEADSHOT NO SCOPE IM SO L33T!!11!1
I do it sometimes too but generally I prefer TDM, or team defender if i feel like going absolutely crazy with my rapid fire extended mags P90 and RPG class![]()
Thanks for the post! The striker is fun to use and awful when people run around with it - seems to do funny things to the game! i thought I would do worse with it but in actual fact I wasnt that much worse!
Quite enjoyed running round with an ACOG MSR last night. Some of the shots I made I thought should have missed and indeed looked like they did in theatre (I know it isnt 100 accurate but I thought I got host a lot because my bros xbox kept overheating the other night and it ended the game both times) and some of the shots I missed I thought were hits.
I was under the impression sniping was actually hard but I reckon if I slapped on quick draw and turned my sensitivity up past 3 I could become one of those annoying kids I despise! Was a bit fun though!
sorray as a bit behind here - but I've Collection 1 already, and only play multi online really - not co-op - which is better for multi Collection 2 or 3 ? or both worth having please ?
many thanks
It's all about K/D ratio init!
Anyone else having trouble playing online? Just tried firing it up in like 2 months and it don't let me go online.
Why the heck does nobody move around the map on this game? Its just one big campfast, whatever the game mode.
I've grown somewhat infuriated with this game, used to play for hrs now I seem to only get 10-30 minutes until something sets me off and I quit the game, tonight it was a combination of a lack of team play, with ppl being more concerned with their k/d ration than winning the match and being unable to hit anyone even when aiming straight at them.
