Road Cycling Essentials
Status
Not open for further replies.
cool pic! BUY IT!
on a unrelated note, which _cheap_ tyres for the next 6-10 months?
Moneys tight and I need to replace my rear, options are as follows
Vittoria Zaffiro Pro Road Tyre
http://www.probikekit.com/uk/tyres-tubes/vittoria-zaffiro-pro-road-tyre.html
Schwalbe Blizzard Sport Tyre
http://www.chainreactioncycles.com/Models.aspx?ModelID=24611
/folding
http://www.chainreactioncycles.com/Models.aspx?ModelID=24609
Conti Ultra Sport Wire
http://www.chainreactioncycles.com/Models.aspx?ModelID=18802
Schwalbe Lugano Road Tyre
http://www.wiggle.co.uk/schwalbe-lugano-road-tyre/
or
Continental Ultra Race Road Tyre
http://www.wiggle.co.uk/continental-ultra-race-road-tyre/
or anything for £15 or less tbh?
After being ill for best part of a week I went out for a ride today on my usual 40 mile hill route. Was setting some great PR's when on the way back I collided with a kid on a bike :(
Descending a hill at 20mph when this kid comes shooting out of a side road from my left, looking over his left shoulder behind him at his mate who was pursuing him on his bike. I slammed on the anchors and shouted at him but he was already in the middle of the road before he saw me and we impacted.
Fortunately for him I came off much worse, I think the sight of a grown man in lycra doing a somersault over the handlebars was the biggest ordeal for him. Moments later a car came down the road going faster than I was, which would have been curtains for him so he learned a pretty important lesson.
His nan saw the whole thing and went a bit berserk at him for not looking. I got a few cuts and a buckled front wheel :( good job I'm looking for a new wheelset ?! Rest of bike looks fine fortunately.
Just got back from 23 miles, finishing by moonlight again. I had one cat 4 in the middle of the ride which nearly killed me - I've a nasty feeling the cold air over the winter is not going to do my asthma any favours.
My gear from Lidl got it's first use... I wore my bib tights, and I think one ride is enough to convert me to bibs. I'm already planning ahead to asking for some nice bib shorts for Christmas, ready for next year's cycling! I also felt a lot happier about being seen in the dark in my little flourescent vest. Lastly, the £5 track pump did a sterling job getting my tyres up to 120psi in about 6 pumps, which was much better than struggling to get to 100psi with the foot pump I keep in the car. Sure, it's tough once it gets beyond 90psi, and the guage sticks a bit, but for £5, I'm very pleased. I'd definitely recommend that anyone without a track pump gets down to Lidl before they're all gone!
Soo Lidl gear is worth a punt?
The track pump is definitely worth getting for £5.
I also have a pair of bibtights which are fleece lined. The quality isnt great and the pad is thin, but that doesnt bother me for shorter rides around 1-2 hours. They keep me nice and warm on colder days and they only cost £10, so IMO they are worth it. Also, for some reason, LIDL call those bibtights a "cycling suit" which makes me giggle a little bit every time i put them on :p
Went for a ride today and managed 55 miles, lovely day except for the wind. Quite pleased as I would normally get back ache, arse ache and neck ache on a long ride but didn't suffer at all. I've been doing quite a few miles recently (both road and MTB) to try and get enough in the legs for the Peak District challenge at the end of Sept, because for someone like me its a tough event! See my sig. :p
http://app.strava.com/rides/20043807
Anyway, tonight I have a sore left knee, a touch of patellar tendinitis which I've had before from playing too much football. Now I now rest will help, but has anyone else had this and what did you do? Did you try altering your cleat positioning or seat height etc? Or was yours just one of those things from over doing it a bit? The bike feels very comfortable generally for the reasons I mentioned above. Ideally I'd like a professional bike fit but they are really expensive, unless anyone knows otherwise...
How often do you check for chain wear generally? My commuter chain has stretched to the point where I have to replace the front chain ring and rear cassette too. I guess if I spotted it earlier I would have only had to pay for a new chain rather than everything?
Can't afford to do that let that happen on the road bike, the cost of replacement Campag Chorus parts would make me cry!
Depends what you are riding on, how tough you are on the bike and how clean you keep it!
Can't hurt to use one of those chain wear devices every few hundred KM though? But which one.....
Just been through the same thing as you, got my bike used, didn't really give much thought to the chain ring being worn out. Fitted new cassette and chain as I had done about 600km so figured it was about due, noticed the big ring was overly worn. Then new cranks time as chainring was NLA, and new BB. Should have just bought a new Ultegra groupset at the end of it!
Get the park tools chainset cleaner, its pretty cheap at Wiggle and generally considered to be better made than the others!
I killed my first chain/chainset through bad maintenance practice - i was over lubricating with a wet oil that just picked up muck and dust and made a nice paste to wear away the metal. Long since learnt my lesson and proper lubrication and chain cleaning has made a difference and i dont have a horrible black chain all the time like i used too....
Well it's my single speed commuter which definitely takes a battering. I do wipe and lube the chain weekly and give it a good scrub monthly but it does get ridden hard in all weather conditions.
LBS are replacing it all today, but they do say that my components were cheap and nasty so I should expect more use from better kit and they said it's normal for SS rear sprockets to be replaced every 1-2 chains, but the front should be fine if I don't let it get so bad next time.
I might buy a chain wear tool from them, but apparently a 12" ruler works just as well?
Status
