NOT my own doing, I'm not sure where it came from but it's been translated from italian, and not by me!
Leaked changelog from the upcoming client patch (start of Sept..?)
Weapons
•Reduced the reload time for: SCAR-L, AEK-971, F2000, AN-94, AK-74, PP2000, G3A3, SKS, MG36, JNG-90, MK3A1, SCAR-H, SVD, QBZ-95B, AUG A3, 44 Magnum, KH2002, PKP, L85A2, QBB-95, M1911, MP7, M4A1, FAMAS, M39 EBR, M416, PP-19, QBU-88
•Increased the reload time for the P90
•Increased the UMP-45 damage at close range, reduced damage at long range
•Increased the PP2000 damage at long range to highlight its midrange role
•Increased the M1911 min damage to make it fit better between the .44 and the M9/MP443
•Reduced damage, range and recoil for the M93R
•Increased the MP412 rate of fire and reload time to highlight the .44's improvement in CQB
•Decreased the SG553 horizontal recoil to make it more controllable
•Decreased the MG36 vertical recoil to make it more controllable
•Decreased the M416 horizontal recoil and FSRM to highlight its difference from the M16
•Increased the M16 & M4 recoil
•Decreased the G36 FSRM
•Increased the bonus given by the bipod with: F2000, G3A3, M27, M416, PKP, Type88, FAMAS, MG36
•Added 3-round burst mode to the MP5K
•Slightly reduced the heavy barrel bonus when used with the 5.56mm, 5.45mm, 6.5mm assault rifles and carbines
•Slightly reduced the suppressor drop off penalty for all 5,56 mm, 5,45 mm, e 6.5 mm weapons: assault rifles, carbines and LMGs
•Slightly reduced the suppressor drop off penalty for the Scar-H
•Increased the LVG 40mm max damage range, damage and gamma are the same
•Solved the Scar-L Heavy Barrel bug
•Solved jets not giving the laser designation bonus
•Solved the AUG M320 Smoke bug
•Increased the mortar damage and damage range
•Added under barrel rail for L85 and Famas
•The G3A3 can now use under slung grenade launchers
•Increased the claymores damage against infantry
•Extended mags re-added for RPK, MG36 e QBB95
•Increased the F2000 vertical recoil
•Slightly increased the AEK-971 horizontal recoil
•Increased the M417 vertical recoil and horizontal recoil
•Slightly increased the JNG-90 reload time, it was statistically better than any other BASR bar the M98B, this will make it balanced
•Slightly increased the SPAS-12 reload time, it is still faster than the 870MCS but slower than pre-patch
•Increased the ACW-R damage since it was weaker than other carbines, adding 6.5mm rounds
•Decreased the AS-VAL vertical recoil
•Increased the RPG accuracy, to make it different from the SMAW distance
Vehicles
•Solved the attack helicopter being unable to destroy deployed equipment
•Increased the damage of jets and choppers rockets against choppers, jets and infantry
•Increased the gunships and IFV damage against choppers and jets
•Increased the AA damage against infantry, decreased against tanks
•C-RAM and Pantisir are now destructible
•Increased the TV missile velocity
•Solved the TV missile exploding after launch
•The air radar now shows friendly aircraft as well as enemy ones
•The jets guided missiles now lock on more quickly
•The LAV gets disabled at 30% health, no longer at 50%
•Decreased the canister shell's damage against infantry and choppers
•Added C-RAM on US carrier on Noshar Canals to avoid spawn camping
Miscellaneous
•Friendly grenades now have a different colour
•The knife is more reliable and relevant for melee attacks
•Slightly reduced the re-fire rate between knife takedowns
•Explosives now remain after death
•Added flag letters on the mini-map
•Reduced the aim assist, now it's slightly better than before patch 1.05 (possibly console patch note?)
•Solved the glitch where in Close Quarters maps and Operation Metro you could go outside the map
•Servers now show the next map at the end of a game
•Changed the ACW-R calibre on Battlelog from 5.56mm to 6.5mm
•Players using fixed weapons emplacements and mortars can now be knifed
•Fixed the sound going out of sync
•All players with at least one Service Star with the SMAW and the RPG can now choose which one to equip
•Premium players can now choose which one of the two knifes to equip (ACB90/Knife)
•Decreased the SOFLAM range
•Added new Master Dog tags for: M9/MP443/M1911 Tact, M1911 Suppressed, M67 Grenade, Repair tool and Defibs
•Removed the mini-map on Hardcore
It's been translated from Italian, so there might be some details lost in translation.
