Why do you refer to them as "good" ones? What is good about them?
Their psychoactive effect profile, generally "designer" drugs don't produce the same positive effects as older and safer established drugs like amphetamines and barbiturates.
Its always youngsters who have just tried their first drug that have the epiphany that drugs should be legalized.
It will wear off over time when you realise the hangovers are not worth it.
Usually down to the cutting agents rather than pure MDMA itself.
As I said, weed and MDMA (as they are the least addictive and harmful of the current prominent drug scene) should be made legal, and regulated heavily. Anything else no.
Apart from Mushrooms.
In fact, as long as you know what you you are doing with MD, the hangover is a very nice feeling.
Pretty bold statements - I imagine many people will disagree with those.
Nadda, The comedown is horrendous but not as bad as base![]()
Yup. The browner MDMA is, the more heroin it has.
That was in particular what I was referring toShrooms maybe.
Mmmm, I disagree to extents. It is potent stuff and has the ability to knock people into pockets of depression for days, even weeks. It has more apparent mental side effects to drugs like alcohol, even if it doesn't make you feel physically ill.However with MDMA, as long as you aren't stupid and take a gram in one go and don't drink any water you'll be fine on the comedown. It's actually helped quite a bit by smoking weed on the comedown!
MDMA is pretty much harmless unless you are an idiot.
Most drugs don't produce hangovers, alcohol is an exception because of it's toxic metabolites.
Ecstacy, amphetamine, acid and cocaine all give a hangover, mostly due to tiredness from not sleeping and a feeling of depression with things like amphetamine.
Lol! I hope that is sarcasm, or you have just completely destroyed any credibility in your opinions on this topic.![]()
That was in particular what I was referring to![]()
I've seen people on shrooms and then come down, and it doesn't seem to be that bad.Mmmm, I disagree to extents. It is potent stuff and has the ability to knock people into pockets of depression for days, even weeks. It has more apparent mental side effects to drugs like alcohol, even if it doesn't make you feel physically ill.
Serotonin levels are the blame though, it's not the MDMA that makes you feel bad, it that how the MDMA makes you feel good leaves you with a depletion in the stuff that makes you feel good afterwards.
This is were individual serotonin levels and natural reproduction rates vary from person to person, and doing stuff like pre- and post-loading (5-HTP FTW) helps mitigate the issues.
If you are generally a gloomy person with low serotonin levels, then you will get hit harder by the comedown than captain happy-go-lucky who eats a diet rich in tryptophan and takes the appropriate supplements.
But that's not a hangover though, being tired because you didn't sleep much is a natural emotion regardless of what caused you not to sleep. That's different to a hangover which is purely caused by drinking too much booze and is the effect of your liver trying to process that alcohol.
By your logic coffee gives you a hangover as it keeps you awake a bit longer which will ultimately result in feeling bit more tired later.
