- 29 Sep 2011
From what i gather, Nvidia.
I think I will stick with AMD , my friend has an AMD card and seems to be doing okay with it regarding running games as far as I know.
I am to nervous about going near Nvidia.
There is always the possibility of having problems with Gpu`s regardless of wether it`s Nvidia or AMD. I just buy the best card i can afford for an alround performance. It will be a while before i need to upgrade. I don`t play online games and play most of my games(SP) on high settings.
I want to play all my games regardless if they are single player or multiplayer on high settings myself.
I have't gotten to play any current gen PC games yet.
Well, a 670 or 7950 will do that.![]()
Not that we will ever need 192 GBs of ram....LOL
14 years ago people were saying "128MB of RAM is obscene! 64MB is the highest we will ever need to go" so I think it is highly likely that 192GB of RAM will become a common sight in 10 years or so.
Trying to choose the right motherboard is frustrating,this whole process of choosing the right parts is, especially regarding the more expensive parts.
Right for what? Pretty much all the recommended mobo's are right for what you require![]()
There have been a mass of right suggestions given to you.
I want to spend a bit more on a motherboard , I am still within budget.
What features are you looking at? It's a gaming pc right?
No point installing both. 32 bit applications will work fine on a 64 bit OS. Retail comes in a nice shiny box and allows 3 activations. OEM only allows 1 activation, but this can be circumvented during activation (usually by calling MS up in the activation process, simple enough).![]()
there is another way................................![]()
Thanks for all the help so far trusty, I appreciate it.
