***The Official Samsung Galaxy S III Thread***
Does anyone know if it is possible to change the vibration pattern for messages? I see you can create custom patterns for calls, but I don't see anything for messages, emails etc.
The stock vibration seems really long, and it's getting on my nerves when on my desk at work and I get emails cosntantly.
Any ideas?
Anyone use Light Flow with the SGS3? I'm struggling getting it to handle the Low Battery LED stuff, and it's killed the built-in one too, so even disabling it in Light Flow won't bring it back.
Just got this about 2 hours ago and already rooted with Busybox and CWM recovery. Could not be any easier using the Toolkit! Genuinely surprised at the ease :o . Anyone worrying about rooting their phone should seriously just man up. It's pretty much aas easy as "type 1, press enter, are you sure? yes. done."
Now to find a ROM...
Edit: decided on Omega v13.1. JB seems to be a bit unstable still at the moment.
Nearly had a heart attack last night when I thought it had wiped all my contacts :eek:
When in flight mode, All contacts names are erased, wtf? then they come back when flight mode is off.
:confused:
hi
new owner of sg3 , i have an issue , when I go into my account settings to check balance and allowance and so on , i click my balance and at bottom it says message sent.
But I dont receive any message?
I looked in message centre settings and the number is different to my actual number , could this be the issue?
thanks
Bah! Max Payne is on special at the moment (85p) but I can't get it as it says the app is incompatible :(
Why can't Google Play allow you to purchase apps even if your current devices don't support it?
