Alienware m18x or m17x r4?
What happened to the days of being able to just up the mem and core with software rather than having to flash :p
Ive not overclocked since the days of my X850XT PE ha ha
Is the m17 and m18 comfortable to game on playing FPS?
Does the keyboard flex at all?
Also would it be a good idea to buy an Alienware from the US? I've found a reseller in the US who are selling Alienwares with much better options for memory and SSD than Dell UK and a hell of a lot cheaper to. They offer IC diamond paste on the CPU and GPU. There laptops come with the option of zero dead pixel and worldwide repair through Dell.
Not sure if I can link to the reseller?
Here's an example of a maxed out m18x r2 from the US supplier.
Alienware M18x R2
18.4" (60Hz) WideFHD WLED (1920x1080) Super Clear Glare-Type Screen
1 Year "No Dead Pixel" Guarantee
Professional Monitor Color Calibration w/ Spyder 3 Elite (Will add to Production Time)
3rd Generation Intel® Ivy Bridge Core™ i7-3820QM (2.7GHz - 3.7GHz, 8MB Intel® Smart Cache, 45W Max TDP)
IC Diamond Thermal Compound - GPU & CPU
680m SLI
16GB DDR3 1600MHz Dual Channel Memory (4x4GB SODIMM)
512GB Crucial C400 Solid State Drive (drive 1)
512GB Crucial C400 Solid State Drive (drive 2)
512GB Crucial C400 Solid State Drive (drive 3)
Slot Load - 6X Blu-Ray Reader + 8X DVDRW/CDRW Super Multi Combo Drive
Bigfoot Networks Killer™ Wireless-N 1202 + Bluetooth 4.0 (Dual Band)
Windows 7 Home Premium 64-Bit Pre-Installed + Drivers & Utilities Disk
2 Year GLOBAL Alienware Advanced Service Plan Warranty (Includes: In-Home Service After Remote Diagnosis + Accidental Damage Protection)
Rushed (Ships in 1-4 Business Days After Order Is Successfully Processed) (Subject to Parts Availability)
5,581.38 USD = 3,535.12 GBP
That's a damn site cheaper than what you can get in the UK.
New 3dmark 2011 test with 12.8 driver rather than 12.7 beta
Score
P5766 3DMarks
Graphics Score
5470
Physics Score
8037
Combined Score
5667
You can just do that, but some people get problems with sync when you overclock, I did, which is why I had to flash it, its fixed now anyway so theres no hassle for future and the temps havent changed really.
Well worth it for the extra 10-15% boost though :)
What do you mean by sync?
I think i shall have a go, what kind of temps does yours run under load and what is safe?
Sam
