Hi all
I've recently acquired one of these lovely monitors but i've been struggling to achieve 120hz at 1080p resolution. The option is available in nvidia settings allowing me to select 1920x1080 with a refresh rate of 60hz/100hz/120hz, but anything above 60hz at this resolution loses clarity and is all pixelated.
Naturally I've been doing some reading and realise that I didn't have a dual link dvi cable (I think this monitor usually comes with the required cable, but I got it 2nd hand and didnt receive one), so I just hooked it up with the dvi cable used with my Dell u2311h. Anyway, I bought a cheap and nasty 5M DVI-D Dual Link from the bay which has the full array of pins but I am still experiencing the same problem.
Im using a MSI GTX460 Hawk which has 2x dvi dual link ports (well the dual link cable fits into both, so I assume both ports are capable of outputting a dual link signal? regardless same issue on both ports).
So can anybody offer suggestions on the root of the problem please?
-Have I bought a crap cable? I assumed a dual link cable was capable of exactly that despite its quality.
-Maybe I've just ended up with a dud cable? although it is working and still displays at 1080p just not properly at 100hz/120hz
-Is there a setting i've overlooked somewhere? maybe in the drivers (which I have updated to the most recent version)
-I read one forum post somewhere just from google searching that explicitly stated something along the lines of 120hz 1080p DVI-D ports on anything from 5 series Nvidia cards and above (might be irrelevant) but did make me consider whether my 4 series GTX460 is capable of achieving 120hz at 1080p.
-I've received a faulty monitor?
thanks in advance
thanks in advance
