Just figured I'd ask in here while my steam support ticket goes through the system, in case there's an alternate fix I can use in the meantime.
I'm having huge problems with dota2. Specifically when I close the game it doesn't exit properly. The exe still shows up in the task manager, steam still thinks it is running, but I can't close it, either using the task manager or process explorer:
http://i.imgur.com/5qRTO.jpg
http://i.imgur.com/xFGmx.jpg
If I run dota2 again it creates another process, and the exact same thing happens, and I imagine it would continue to happen until I ran out of available memory and something bad happens. Is there anything I can do from my end to properly kill it or do I need to just wait to hear back from Valve?
