I would DEARLY like to see some MXM cards on here to go with these.
Being able to buy a wider set of laptop components off here would be nothing short of amazing.
any chance of doing one under a grand
Gibbo- try a 15.6" version and allow a build based on a gtx 680m and you'll flog barrow loads of them
Perhaps offer more in the way of storage devices and clarify whether a 2nd drive would negate the use of an optical drive?
670 is still slower than a 7970 with utilisation issues lol.
Personally I'd happily skip the optical and take a laptop optical in a self powered USB case for the few occasions you'll use it (or just switch it with a bulk media drive in the ODD caddy thing as needed.)
A good idea, but that leaves a big hole in the side of the machine??
Hi there
We are bringing more different chassis and VGA options in.
2nd HDD has no effect on install an ODD in this chassis.
My one here has a 128GB SSD and a 1TB HDD along with ODD installed, no issues.![]()
thanks for the response. Ive been weighing up laptop v self build desktop for a while and just cant pull the trigger on either for some reason. Your drive set up would be similar to what id be looking for. Would definately prefer a cooler card than the AMD offering for a laptop
