Obligatory 1k on a chair :S:S:S
i would consider my life as 'going downhill' if i could only afford to spend a grand on a chair, £2k is the minimum id spend
More like... no, not really. I know what I'm doing, thanksMore like it just enabled you to sit in a position that didn't make incorrect posture hurt.
Whatever you don't buy a a lower end Herman Miller aka Aeron or Mirra.
They are very poor chairs by today's standards. The embody is fine as it has active back support, and does not cut off circulation to the lower legs.
The Aeron is 13 years old - and isn't that great by today's standards. The Mirra on the other hand is absolutely fine.
Price aside, it is a very good chair. It holds the FIRA Ergonomics excellence award and is used as the standard demo piece for whatever government body deals with health and safety education.They are in effect the same chair, all be it with a few tweaks. The mirra is shockingly bad for it's price point. There are far far better options out there for a similar price point.
Hi,
Over the last 6 months I've tried out quite a few office chairs from Staples and currently have an Ikea Markus, but they all hurt my back after a few hours of use. I work as a programmer so sit for 6-10 hours a day (with breaks).
I'm considering trying out the Herman Miller Aeron Office Chair, Size B (a massive step up in price at £899 but returnable within 7 days if it's no good), I also saw the Herman Miller Embody chair recommended, but can't find any shops that stock it with a decent return policy.
Does anyone have feedback on the Herman Miller Aeron B, or recommendations for other chairs before I try the Herman Miller?
Thanks in advance.
