- 30 May 2012
- Bristol
Thank you so much for the information. By the way is it worth getting FX 6100? or is there any alternative better than that? What do you recommend ?
I agree with the other poster who said not to get the 6100. AMD Bulldozer CPUs are pretty bad when compared with Intel's offerings at the same price. I'd recommend getting a 3570k, it does cost more than a 6100 but it delivers the performance to warrant it. If you ask anyone on here, they will tell you it is the ideal gaming CPU for the price, especially if you overclock it.
. Also the megaflows use crappy sleeve bearings that dont last as long as ball bearings or fluid bearings. They might end up getting louder as the sleeve bearing wears.
