Caporegime
- 18 Sep 2009
- Dormanstown.
Why do people bother with this?...I've had my NB running from 2Ghz to 2.6Ghz and found the difference in benchmark scores to be absolutely minuscule, the only big difference it made to my rig was the hotter temps.
Are you sure it wasn't the HT link you raised?
CPU NB is well documented to give a performance increase, I've noticed the difference myself.
Raising my CPU NB I was able to get my Phenom II to slightly pass that of a Q9 Core 2 at the same clock in some situations, whereas prior it would have had lower performance using a normal 2GHZ CPU NB.
