Road Cycling Essentials
Status
Not open for further replies.
Been trying to build endurance over multiple days and seems to be going well in the last week:
Tue: 40 miles
Wed: 50 miles
Fri: 35 miles
Sun: 65 miles
Going to take a couple of well earned rest days now :)
How did you make your mount and can we have some pics please?!! :)
When I got the bike from Decathlon it came with lights, front and rear. They unclip and slide off like most lights do. My phone has a leather case with a plastic holder glued to the case thing.. I took the plastic holder off and put a screw into it and screwed it into the light mount. Its secure and firm. I will get some pics up in a short while.
Put it this way, it works..:D
Pics.
This one is the Light mount. I fixed it to the stem.
This is the phone case with the plastic holder.
This is the holder removed from case.
This is the holder screwed into the light mount.
Slimline......
Edit: I put a little tape over the screw head so it doesn't scratch the underside of the phone.
Just had the worst cycle home ever, weather wise.
I went segment hunting :) so took a slight detour on the way home. But as soon as I got to the start of the segment section I was hit with the strongest headwind I've ever ridden in, I was even having to pedal hard down the hills. Then halfway through the section the rain started and didn't finish until I got home. Ended up with an average speed of 15.4mph which is well off my usual pace.
I still enjoyed it though. This mornings cycle in to work made up for it.
ordered those shoes with spare cleats and hope they will work together ;)
had a really bad experience at Evans today...first guy passed mine requests about shoes to some other guy that looked like he didnt wanted to work there at all not to mention being asked for some things...ended up walking out without shoes but found ones I liked...they have lost a customer..
@minty Good job. That's on a Canyon right?
cheers dude. Wasnt exactly the fastest overall speed but felt good to do a longer ride than usual.
Im not on a canyon, im using a litespeed m1.
You have racked up loads of miles in one week. Top Job! I dont know how you do it, my legs are sore after the ride today god knows what they would be like if i tried to do that a few times a week.
Thanks for taking the time to post. Really good job you've done there :)
I've tried a few different things to make the phone stay put on the stem like that but none have looked as good as yours! I'll be on the lookout for a similar light fitting!!
Is the phone rock solid in the housing that you've fitted onto the stem?
no not at all
i asked for recomendations and 3 guys were helpful, but noticed some pedals have a bit at the front that your toe goes into , some do have it, others don't im guessing its best to get one with it?
i.e. http://www.chainreactioncycles.com/Models.aspx?ModelID=50512
over the A530's
Pedals that take cleats dont have toe clips. Toe clips and straps are old fashioned now because clipless pedals do the same job but let you get your foot out much quicker. Get a clipless pedal + cleats rather than a flat pedal with toe clips.
You learn something new everyday! Cheers fella
The phone is very snug in the case holder as you would expect as that's what's it for. The way I have fitted the whole thing to the stem is only using the original rubber band thing that fits the light bracket to the bars. If I get chance tomorrow I will get some better pics up. Hard to explain unless you know what the light fittings are like from decathlon....
Iirc the phone case cost me£10 had it for nearly two years. Solid build too. Only thought abouT using it for the phone holder today. Glad I did.
Bad day for me today....after thinking about adjusting seat for few weeks finally got tonight...and broke clamp holding west in its position....not sure why it snapped as I wasnt making it too tight and wasn't using too much strength to tight it...no cycling for me until I get a spare....
Status
