The tripod arrived today, the returns sticker said it came from the UK so they must have a distro warehouse somewhere here.
Anyway, what do I think of it? Well it's not as quality feeling as the RedSnapper as far as the plastics used go but other than that it feels good enough to hold my 5D3 + 1.4 glass. The legs are thinner than the RS legs and the centre column is as well so I can't use the RS shorter column on this which is a shame as it spider legs as well as the RS tripod does. The ball head movement is not as smooth as the RS ball head I have (RSH-12) but the ball is smoother and the quality of the head is near enough the same as the RS head.
Because the legs are thinner, there is more flex in them than the RS tripod, this may be a problem if the tripod is extended fully but I never use it like that so not an issue here. The base plate and bracket is of the same design and shape as the RS parts so I don't need to swap plates around when switching pods.
The monopod section is actually very neat. If anything, this is a £100 carbon fibre monopod
The compass on the end of the ball head adjuster knob seems pointless as it's pointing sideways (!).
It doesn't have spiked feet options like the RS tripod does.
The bag that comes with it is padded but the strap is not so the RS bag is of much better standard for carrying and comfort. it also doesn't have an inside zipped pocket like the RS one does. The RS bag costs £10 from them direct and to this day I have not seen a better bag for that kind of price. Truly remarkable given how good the quality of it is.
Sad news time though, my RS ball head has stopped panning, like it's seised in its position
I've emailed RS about this as well as a small issue with 2 of the legs and am awaiting a reply as they said to send a message on TP forum in the big RS thread.
Pics:
Verdict?
It's definitely a decent backup tripod but as a primary tripod to be used outdoors under varying weather conditions I'd always have something a bit beefier. I'm hoping RedSnapper can sort out the faults that have cropped up on my ball head and tripod legs because I really do like that otherwise I will probably look elsewhere. There's no reason why a quality ball head like the RS one should seize up!
Pics:
Verdict?
