I was all set to hit the button on a Ribble winter 7005 frame and it turns out it won't take 28mm tyres and mudguards.
So... can anyone recommend a decent frame of a similar budget as the Ribble Winter that takes 28mm tyres with mudguards that would be ideal as a winter hack?
do you really need 28mm tyres?
with that kinda requirement I'd day cyclocross as I'd doubt a normal road bike will take that size?
