Road Cycling Essentials
Status
Not open for further replies.
beware of ebay sellers for sl pedals
half of them say NIB but dont mention the cleats and they remove the cleats and keep em
It's odd that the cleats would come with the shoes.
3 bolt shoes are compatible with most road pedals so they could have any cleats on them but pedals are only compatible with 1 make of cleats, so it's more likely that you'll get the cleats with the pedals.
Actually, sorry, my bad, i got them with the pedals but threw all the packaging away outside the shop so i could put the pedals and shoes in my bag to ride back with, i was sure they came with the shoes but thinking about it, it was with the pedals.
Mr Russinating, did you get your new bars fitted? I'm intrigued to see how they sit on the bars as I'm in the market for some myself. Thanks.
Haven't fitted them yet because the bolts it was supplied with aren't long enough to fit around my bars. Going to pop to my local handyman shop at some point to get some longer ones.
I'll be using them on Sunday properly so will post how they are after that.
Just a foot pump, inflate to 60psi and pop tubes are good for 116psi.
Curious. What rim take have you used? Hard plastic, rubber or canvas? Is it a snug fit on both edges of the rim? Are you 100% sure you're not pinching the tube when you put the tyre on (i.e. inflate it slightly so it sits in the tyre when you lever the tyre over the rim)? You're not using a Presta valve in a Schrader valve-sized hole (Schrader valve holes are about 2mm bigger)? I think you need to run your finger round the entire inside edge of the rim looking for any sharp edges and take a double check around the tyre for anything stuck in it. The final thing I can think of is if it's an older non-beaded rim, because anything over about 60psi can have a habit of lifting the tyre bead away from the rim and you can get a tube go pop that way. It would have to be a wheel made earlier than the early 80's though.
Those shoes are virtually sold out unless you happen to be a size 38, but that combo is fine as it's what i use. One word of warning if you order Shimano shoes though is that Shimano are small on sizings so order a size 1-2 larger then you usually take.
Thanks Diablo, i know im a size 9, i dont go by Euro sizes! i shall convert it though! Chainreaction have those shoes on offer at the moment at a cracking price!
UK 9 you would probably wan't a Euro 45 as road shoes are normally sized smaller than a regular shoe so as a general rule of thumb you go a size up.
But it's worth dropping into somewhere like Evans and trying on a 44-45 in a couple of brands to see which is the better fit. They also do wide versions of most road shoes.
@ Firestar_3x and anybody else with a boardman bike
i keep telling myself that i should get the Alu framed one. but i also keep telling myself to go for the carbon one, and to be honest, i really dont know :confused:
hopeing to get one this week or next but i just can't decide!
I think it depends what you expect or want out of a bike, several things pushed me towards the carbon, weight / ride comfort and longevity being several of the factors.
I didn't really want to sink £800 - £900 into an alloy bike then sell it at a loss after deciding I’d rather have the carbon one.
I'm a 9 with wide feet and 43s were too small for me, but 44s are fine. I think 45s would be too big. But yeah, you're right, best bet is to try in store to be sure.
I've got the alu one and I love it. If I'd have had another couple of hundred in my budget would I have gone for the carbon one? I think I would have yes.
I don't think you can go far wrong either way, if you get the alu you will have more money towards the other kit but as someone else has said if you really want the carbon one you don't want to be regretting buying the alu one in a year or so. If you have the money and you think you want the carbon one, you might as well go for it :)
I've got the Boardman Team Carbon, all I can say is that I absolutely love it. It's fast, responsive and I got it for a ridiculously good price that I would have been stupid to choose anything else.
I bought another Boardman Team Carbon having sold the one i had 6 months earlier.
I got the older model 2nd hand from the bay, it comes with SRAM Rival which is Ultegra equivalent (i believe the current model has Shimano 105). Cost me £650.
Also bought some Shimano road shoes in a 44 (i'm a UK 9 in anything i buy), they were too narrow so took them back (i live near Ribble).
Bought some old style DHB R1 shoes 2nd hand, nice saving and i knew they fit well (in a 44) as i'd had some previously.
Rival is 105 equivalent. Force is about equal to Ultega and Red is the equivalent of Dura Ace.
I say equal and equivalent but we all know SRAM is better.
Status
