I don't like the blue LEDs on the fans
Is Scythe Gentle Typhoon fans the best or is there others?
not the best if you want silence from my experience.
For airflow and silence then there is much better than GT's they have a sort of whirrr that you can't shake.
I'm used to my 1850's at max rpm now tbh. If i wanted more silence i should have bought a sturdier case than my lian li the price you pay for vanity xD
Would look at the noiseblocker range to be honest. very good fans Or the akasa apache blacks. very quite and pretty efficient.
