what low profile cpu cooler under 100mm for overclocking?
on the width you mean? hitting the cage?
the height looks like it will
The one in the picture above the Noctua NH-L12
Height (with fan) 93 mm
Width (with fan) 128 mm
Depth (with fan) 150 mm
NH-C12P
Height (with fan): 114 mm
Width (with fan): 140 mm
Depth (with fan): 152 mm
NH-C14
Height (with fan) 130 mm
Width (with fan) 140 mm
Depth (with fan) 166 mm
think im going to go for the Noctua NH-L12 to be honest :)
i think so too
looking at these 2 pics
you couldnt have any taller with being able slide the motherboard tray in and out
http://images.tweaktown.com/content/4/8/4806_31_lian_li_pc_v355_b_mini_tower_chassis_review.jpg
and you couldnt have any wider without it hitting that cage
http://images.tweaktown.com/content/4/8/4806_36_lian_li_pc_v355_b_mini_tower_chassis_review.jpg
Noctua have very quiet fans on them usually
