** New Gigabyte boards coming soon! **
20 Jul 2009
Midlands
Hello
Got a few new boards cominbg very soon. Some much needed ivy-bridge levl m-itx and the storming new Z77X-UP7 :D
Take a look below :)
Gigabyte Z77X-UP7 Intel Z77 (Socket 1155) DDR3 Motherboard @ £319.99 inc VAT
GIGABYTE has unleashed its latest flagship Z77X-UP7 Motherboard. Designed for extreme overclocking, the GIGABYTE Z77X-UP7 motherboard is for serious overclockers looking to take down world records. Currently the Intel® Core™ i7 CPU world record holder at 7.102GHz, the GIGABYTE Z77X-UP7 is this year’s overclocking motherboard to beat.
The GIGABYTE Z77X-UP7 motherboard delivers some serious amount of power through its 32+3+2 power phase design (32 CPU phases, 3 Intel® HD Graphics, 2 VTT phases). Featuring the new GIGABYTE Ultra Durable™ 5 technology with high current capable components including 60A rated PowIRstages® from IR, the Z77X-UP7 is able to deliver an astonishing 2,000W of power delivery.
CPU
Support for Intel® Core™ i7 processors/Intel® Core™ i5 processors/ Intel® Core™ i3 processors/Intel® Pentium® processors/Intel® Celeron® processors in the LGA1155 package
L3 cache varies with CPU
(Some Intel® Core™ processors require a graphic card, please refer "CPU support List" for more information.)
Chipset
Intel® Z77 Express Chipset
Memory
4 x 1.5V DDR3 DIMM sockets supporting up to 32 GB of system memory
* Due to a Windows 32-bit operating system limitation, when more than 4 GB of physical memory is installed, the actual memory size displayed will be less than the size of the physical memory installed.
Dual channel memory architecture
Support for DDR3 1600/1333/1066 MHz memory modules
Support for non-ECC memory modules
Support for Extreme Memory Profile (XMP) memory modules
(Please refer "Memory Support List" for more information.)
Onboard Graphics Integrated Graphics Processor:
1 x D-Sub port
1 x DVI-D port, supporting a maximum resolution of 1920x1200
* The DVI-D port does not support D-Sub connection by adapter.
1 x HDMI port, supporting a maximum resolution of 1920x1200
1 x DisplayPort, supporting a maximum resolution of 2560x1600
Audio
Realtek ALC898 codec
High Definition Audio
2/4/5.1/7.1-channel
Support for S/PDIF In
Support for S/PDIF Out
LAN
1 x Atheros GbE LAN chip (10/100/1000 Mbit) (LAN1)
1 x Intel GbE LAN chip (10/100/1000 Mbit) (LAN2)
Expansion Slots
3 x PCI Express x16 slots, running at x16 (PCIEX16_1~3)
* For optimum performance, if only one expansion card is to be installed, be sure to install it in the PCIEX16_2 slot.
2 x PCI Express x16 slots, running at x8 (PCIEX8_1~2)
* The PCIEX8_1 slot shares bandwidth with the PCIEX16_1 slot and the PCIEX8_2 slot with PCIEX16_3. The PCIEX16_1/PCIEX16_3 slot will operate at up to x8 mode when the PCIEX8_1/PCIEX8_2 is populated.
(The PCIEX16 and PCIEX8 slots conform to PCI Express 3.0 standard.)
* Whether PCI Express 3.0 is supported depends on CPU and graphics card compatibility.
* The PCIEX16_2 slot will become unavailable when an expansion card is installed in the orange PCI Express x16 slot.
2 x PCI Express x1 slots
(All PCI Express x1 slots conform to PCI Express 2.0 standard.)
Multi-Graphics Technology
Support for 4-Way/3-Way/2-Way AMD CrossFireX™/NVIDIA SLI technology
Storage Interface Chipset:
2 x SATA 6Gb/s connectors (SATA3 0~1) supporting up to 2 SATA 6Gb/s devices
4 x SATA 3Gb/s connectors (SATA2 2~5) supporting up to 4 SATA 3Gb/s devices
1 x mSATA connector
* The SATA2 5 connector will become unavailable when the mSATA connector is installed with a solid state drive.
Support for RAID 0, RAID 1, RAID 5, and RAID 10
* When a RAID set is built across the SATA 6Gb/s and SATA 3Gb/s channels, the system performance of the RAID set may vary depending on the devices being connected.
2 x Marvell 88SE9172 chips:
4 x SATA 6Gb/s connectors (GSATA3 6~9) supporting up to 4 SATA 6Gb/s devices
Support for RAID 0 and RAID 1
USB Chipset:
Up to 4 USB 3.0/2.0 ports (2 ports on the back panel, 2 ports available through the internal USB header)
Up to 4 USB 2.0/1.1 ports (available through the internal USB headers)
VIA VL800 chip:
Up to 4 USB 3.0/2.0 ports on the back panel
* Due to a Windows 7 limitation, please connect your USB device(s) to the Intel controlled USB port(s) (located below the PS/2 keyboard/mouse port) before the VIA USB 3.0 controller driver is installed.
Etron EJ168 chip:
Up to 2 USB 3.0/2.0 ports (available through the internal USB header)
Internal I/O Connectors
1 x 24-pin ATX main power connector
2 x 8-pin ATX 12V power connectors
1 x PCIe power connector
6 x SATA 6Gb/s connectors
1 x mSATA connector
1 x CPU fan header
6 x system fan headers
1 x front panel header
1 x front panel audio header
1 x S/PDIF Out header
1 x S/PDIF In header
2 x USB 3.0/2.0 headers
2 x USB 2.0/1.1 headers
1 x serial port header
1 x Clear CMOS jumper
1 x power button
1 x reset button
1 x Clear CMOS button
1 x Gear button
1 x CPU BCLK Down button
1 x CPU BCLK Up button
1 x CPU Ratio Down button
1 x CPU Ratio Up button
1 x onboard voltage measurement module
2 x BIOS switchs
1 x LN2 switch
Back Panel Connectors
1 x PS/2 keyboard/mouse port
1 x D-Sub port
1 x DVI-D port
1 x optical S/PDIF Out connector
1 x HDMI port
1 x DisplayPort
6 x USB 3.0/2.0 ports
2 x RJ-45 ports
6 x audio jacks (Center/Subwoofer Speaker Out/Rear Speaker Out/Side Speaker Out/Line In/Line Out/Microphone)
I/O Controller
iTE I/O Controller Chip
H/W Monitoring
System voltage detection
CPU/System temperature detection
CPU/System fan speed detection
CPU overheating warning
CPU/System fan fail warning
CPU/System fan speed control
* Whether the CPU/system fan speed control function is supported will depend on the CPU/system cooler you install.
BIOS
2 x 64 Mbit flash
Use of licensed AMI EFI BIOS
Support for DualBIOS™
PnP 1.0a, DMI 2.0, SM BIOS 2.6, ACPI 2.0a
Unique Features
Support for @BIOS
Support for Q-Flash
Support for Xpress Install
Support for Xpress Recovery2
Support for EasyTune
* Available functions in EasyTune may differ by motherboard model.
Support for eXtreme Hard Drive (X.H.D)
Support for Auto Green
Support for ON/OFF Charge
Support for Q-Share
Support for 3D Power
Support for EZ Setup
Bundle Software
Norton Internet Security (OEM version)
Intel® Rapid Start Technology
Intel® Smart Connect Technology
Intel® Smart Response Technology
LucidLogix Virtu MVP
* Make sure the monitor cable has been connected to the integrated graphics port on the back panel.
Operating System
Support for Microsoft® Windows 8/7/XP
Form Factor
E-ATX Form Factor; 30.5cm x 26.4cm
Only £319.99 inc VAT.
ORDER NOW
Gigabyte Z77N-WIFI Intel Z77 (Socket 1155) DDR3 Mini ITX Motherboard @ £98.99 inc VAT
The New Z77N-WIFI from Gigabyte gives you all the features of a fully overclockable Z77 chipset with the mini form factor of M-ITX making it perfect for a high end ultra compact PC.
CPU
Support for Intel® Core™ i7 processors/Intel® Core™ i5 processors/Intel® Core™ i3 processors/Intel® Pentium® processors/Intel® Celeron® processors in the LGA1155 package
Chipset
Memory
2 x 1.5V DDR3 DIMM sockets supporting up to 16 GB of system memory
Support for DDR3 1600/1333/1066/800 MHz memory modules
1 x DVI-I port, supporting a maximum resolution of 1920x1200
2 x HDMI ports, supporting a maximum resolution of 1920x1200
Audio
Realtek ALC892 codec
2/4/5.1/7.1-channel
LAN
2 x Realtek GbE LAN chip (10/100/1000 Mbit)
Expansion Slots
1 x PCI Express x16 slot, running at x16
(The PCIEX16 slot conforms to PCI Express 3.0 standard.)
2 x SATA 6Gb/s connectors (SATA3 0/1) supporting up to 2 SATA 6Gb/s devices
2 x SATA 3Gb/s connectors (SATA2 2/3) supporting up to 2 SATA 3Gb/s devices
USB Chipset:
Up to 6 USB 2.0/1.1 ports (4 ports on the back panel, 2 ports available through the internal USB header)
1 x 4-pin ATX 12V power connector
1 x USB 3.0/2.0 header
1 x CPU fan header
1 x system fan header
2 x HDMI ports
2 x antenna connectors
1 x DVI-I port
2 x USB 3.0/2.0 ports
4 x USB 2.0/1.1 ports
2 x RJ-45 ports
5 x audio jacks (Center/Subwoofer Speaker Out, Rear Speaker Out, Line In, Line Out, Mic In)
I/O Controller
H/W Monitoring
CPU fan speed control
* Whether the CPU fan speed control function is supported will depend on the CPU cooler you install.
BIOS
2 x 64 Mbit flash
Unique Features
Support for @BIOS
Support for Q-Flash
Support for Q-Share
Bundle Software
Operating System
Form Factor
Mini-ITX Form Factor; 17.0cm x 17.0cm
Only £98.99 inc VAT.
ORDER NOW
Gigabyte H77N-WIFI Intel Z77 (Socket 1155) DDR3 Mini ITX Motherboard @ £89.99 inc VAT
CPU
Chipset
Intel® H77 Express Chipset
Memory
* To support DDR3 1600 MHz, you must install an Intel 22nm (Ivy Bridge) CPU.
Audio
2/4/5.1/7.1-channel
LAN
Expansion Slots
USB Chipset:
1 x CPU fan header
2 x HDMI ports
1 x DVI-I port
2 x RJ-45 ports
I/O Controller
H/W Monitoring
BIOS
2 x 64 Mbit flash
Unique Features
Support for @BIOS
Support for Q-Flash
Support for Q-Share
Bundle Software
Operating System
Form Factor
Only £89.99 inc VAT.
ORDER NOW
Wow...that Z77 itx board looks tempting for a HTPC build
Cracking price too, compared to other Z77 ITX boards.
my wee heart lit up there when i saw the gigabyte orange board that would go so well with my gigabyte orange mayhems fluid.
it sank again when i saw the price.
i need a hug
I been waiting for this UP7 and Ivybridge to go together. Are the price £319.99 inc VAT are only for pre-order or will the price go up once it available in stock ?
Been waiting for these new mini itx boards from Gigabyte for a few weeks now, ever since I saw a preview of them.
Excellent news they will be available soon :)
How soon is soon?
The Gigabyte Z77N-WIFI looks fantastic, I've always preferred Gigabyte motherboards. (Plus dat black PCB) :p
Did I miss it, or is there no Thunderbolt on the UD7?
I know you can't fit everything onto one mobo, but they seem to have added everything else.
Or will there be a UD7-TH too?
