- 29 Aug 2010
- Cornwall
Right so after initially buying a TJ11 from OcUK when they were on offer, I then sent it back after deciding that it would be too awkward trying to fit in the watercooling that I wanted.
I've now bought rjk's TJ11 and don't have the option of sending it back, so gonna have to try to make it work. Although initially I'll probably run it air cooled I do expect I'll end up watercooling eventually.
So was hoping I might be able to get a bit of advice.
I'm hoping to cool 3 (maybe 4) graphics cards (currently 670s), a 3930K and quite possibly the R IV E chipset.
I'd prefer not to mount the pumps in the 5¼" bays as I've had issues with vibrations before. I'm ok with a bay res though, in fact might actually prefer it so I can easily see coolant level.
I'd like to use 2 x D5 pumps. Partly as I'm hoping it'll mean I can run them on a slower speed, but also to give me some redundancy. Where can I place the pumps?
I'll probably put a 120mm rad on the top exhaust. In the bottom I'm not sure whether to try to fit a 560mm and 280mm (probably XSPC EX rads) or go with a 480mm and 240mm (again probably XSPC EX rads).
My concern with 140mm rads is finding decent fans, where as with 120mm rads I can just use my GTs.
Also I believe the 120mm EX rads have multiport options. I was thinking with one of these I could fit a QR fitting to one of the unused connection and then plug the other end of the QR in when I wanted to drain the loop. Do QR fittings seal well enough to make this viable?
My other option is to put the pumps (and res) in the lower section and then use an external 1080mm rad and stand?
Also with the cpu block, do you need to change the orientation in a case like the TJ11 where the motherboard is rotated? Is there a right way up for a EK Supreme HF block?
Thanks.
Thanks.
