I've just ordered the Palit GeForce GTX 670 Jetstream, should be here tomorrow![]()
I read they are quite noisy. I could be wrong though and would be interested to hear your verdict.
670 FTW ? comes withe stock 680 heat sink & pcb and 145% power target. Also gets all that hot air out of the case, Perfect if you would like to go sli later?
I have the palit jetstream and tbh I don't find it that noisey but noise from a gfx card is a very subjective thing I guess. Very happy with the cardd for price/performance
I benched mine with heaven when I first had it and got the following:
max temp: 78c
max fan speed: 62% 1920 rpm
max gpu load 99%
max core clock: 1150 Mhz
max mem clock : 1527 Mhz
max vddc : 1.1620
max power consumption 94.1%
Should probably add my setup: i5 2500k oc'd to 4.8 under an Antec Kuhler 920, ssd, ASRock Z68 extreme 4 mobo and all wrapped in a coolermaster silencio case which, when I do a rebuild I'll be replacing as the air flow is shocking. plus the silencing foam insulates it all.
Yeah I had an Antec 300 previously and some good airflow. I run mine on an Antec Gamer 620w psu as I previously had a 570.
