Underpeforming 7870
The 2500k ain't that good at stock - I would bump it to at least 4.4 Ghz which any chip will easily do with minimal voltage adjustment.
4.4 Ghz with volts on 1.36V will be stable I'd say. You can reduce it from there if you like.
Lol
Just running the standard clocks
turbo at 3.70 ghz i think it is mate
EDIT
2500K mate
Well your setup should be fine to run most things at high, or close to highest settings. Max payne 3 should run well so long as you disable AA.
Let us know if you have further problems.
My 2500k does 4.5ghz stock volts. 1.33-1.34 I think stock is.
Some games really do benefit from a CPU overclock as well.
Running my cpu at 3.7ghz or 4.6ghz i see very little difference in performance on max payne 3 and battlefield 3.
A few extra fps sure, but at stock neither of those games are cpu bottlenecked afaik.
Likely you're running graphic settings that are too high for your gpu.
Try running the HIGH setting preset in bf3 and let us know how you get on.
Ok mate so that worked
When i run 3dmark though, the fps is higher but it like its throttling back somehow
Once it throttles back the sppeds are better but its in the 50s for about 5 seconds then you see a massive drop all of a sudden
You need to increase the power limit meter in afterburner to +20 before attempting any sort of overclock.
Yeah I had to do this when attempting to clock my 6950. Don't enable overdrive in CCC as that and afterburner seem to conflict with each other from my experience.
Yes, spot on spenty. Don't touch overdrive, let afterburner do the work to rule out possible conflicts.
thanks mate :D
hey do you want a free copy of nexuiz ?
I got it with the card today
you can have it for all your help if you like :)
Thanks man, very kind of you.
I don't want to sound rude or cheeky but i don't suppose you have a spare copy of dirt showdown or sleeping dogs instead do you?
If not don't worry, my help is free.
I already have a copy of nexuiz, its not really my cup of tea to be honest. (I'm a pg tips man :D)
If you need any more help, just give us a shout. :)
Bloody hell you are sounding rude and cheeky :p.
Well i imagine he got free copies of those as well so if the offer is on the table i will gladly accept, if not then no biggie.
Never get tired of helping fellow amd brethren, just like someone helped me to learn a long time ago.
Sorry mate i activated the other 2 games on steam earlier :D
If only i had got to you sooner you could have had them.
Sorry mate i feel bad now :(
lol
