Caporegime
- 29 Aug 2007
- Auckland
SHOULD I PEE ON MY LAWN? THIS IS IMPORTANT
Conceptually stupid even on a basic level.If when you look through a telescope at distant galaxies, what you see happened millions of years ago because the speed of light is quite slow.
The universe is also expanding so the galaxies are getting further away. Eventually they will be so far away that it will be too far for even light to reach us. If you think of the speed of light as the maximum speed of information transmission, no information could be exchanged with those galaxies.
In effect those galaxies are now in separate universes. It's beyond the range that information can be exchanged with our one so they cant effect each other.
I lol'd at the troll.If when you look through a telescope at distant galaxies, what you see happened millions of years ago because the speed of light is quite slow.
Incorrect. The speed of light is a local limit. The expansion of the universe is a stretching of the very fabric of spacetime itself - it's very possible for objects hundreds of billions of light years away to be moving away from us at greater than the speed of light. Seriously, google "cosmological horizon", I'm not making this **** up.
Kwerk,
You have such a misunderstanding of physics words fail me, you have totally got the wrong end of the stick.
Kwerk,
Cant be bothered go into it as im off out now, but your comment I skim read about 'jumping out of an air craft and the ground speeds away' in an attempt I assume to explain expansion is incorrect.
You fail to consider the plane, the space between the plane and the person jumping out are expanding as well, hell us sitting at the computer now are expanding right now, its not perceptible but its happening.
So the galaxies are drifting further apart sure, but its not as simple as that.
What will really bake your noodle is, if everything is expanding 'equally', thus the relative distance shouldn't change, because it you and the object are expanding, yet the galaxies are measurably getting more distant, may blue screen your mind,lol.
But what is this distance to the horizon once it has been reach??!?!except point A is separating from point B at exponentially increasing speed because of the time differentials. The further away it gets the faster it is moving away. Eventually point C will be separated from both points too. Once the inflation speed starts going straight up on the exponential curve (i.e. the distance to the horizon has been reach) it is basically infinity distance away. It's gone forever, even if you tried to relay through a half-way point C. There can be no information exchanged either way ever again even if you move towards it at light speed. It has basically forked off as an independent sub-universe.
"Expanding from the centre"? What centre?
There isn't one...everything is expanding away from everything else....including the atoms in your body.![]()
