Dude seriously it is just on your taste really, just pop into a shop and try both of them, which ever you like just get it.
This.
but the s3 felt cheap and as if it could break very easily
What would you pick if it was you?
Back to iOS, I believe that the newer iPhones have a much higher screen DPI than the current Androids.
Every specs S3 has beats the iPhone 5?
I'v tried Android OS before but not iOS
I want the best phone with my money
As others have said - try both. Specs wise both are awesome so really just comes down to iOS or Android which is an argument that's very specific to the user.
What sim card does the S3 uses? Also using a 64GB Class 10 SD card will improve loading performances?
It uses a micro sim, loading times are as fast as they get really, the SD card wont change that. People use class 10 for the faster transfer speeds when moving large amounts of data to your SD card.
Android is for the tinks, and that accounts for most of this web site's demographic.
