Asus Maximus V Formula Preview/ Results/ everything Thread!!!
got my v formula and bought a usb 3 module to replace the usb2 one in the front of my tj07. now it's got 2 usb plugs and i think the formula has only one usb3 plug. how can i plug both in ???
My system is still really jumpy on start up but once everything is up and running no issues at all... really weird
well clocked it to 4.6ghz now temps at load 60 ~ 62 c probably can push more as tjmax is higher but atm is enough , mem wasn't stable at those timings now trying bit looser. all good
Hi,
I take the Maximus Formula V with Corsaire Vengeance 4 x 8 Go DDR3 PC3-10700 CMZ32GX3M4X1866C10 but on the mother card only Dimm Slot B1 and B2 recognise the memory.
When I want to use A1 and A2 Dimm slot I have this Qcode 55...
I've tried to ClrCmos, to update bios, to GoButton,to check Cpu socket pins but all ok, to put only one in the A2 first but don't work.
Only on the Dimm Slot B1 and B2.
I don't know what to do ??...
For information my configuration : Intel Core i7 3770K - NVIDIA GeForce GTX 680 - SSD M4-CT512M4SSD1 500 Go SATA III - Ventirad Watercooling Corsair H100 Hydro Series
Well the woes continue with the Maximus V Formula. Potentially the 3rd one being sent back under RMA. Been running the stock BIOS with no problems. I then got thinking that I wanted to install the Bluetooth/Wi-Fi module. Install's the hardware no problem. I then come to install the software but there is no hardware to be found :confused:
I reboot and attempt to go into BIOS to see if there is any settings in there to change, BIOS you say, Press Delete and it's a black screen, Clear CMOS and press F1 to run set up and another black screen. So now I have a motherboard that I can't even get into BIOS.
When I restart the sytem or boot from a power off, it goes straight to Windows with no option of loading into BIOS.
Any suggestions on another way I can get into BIOS ?
I have tried the next revision of BIOS and am on 0701 now from 0502
I had such high hopes for this board but it has been one problem after another.
Loki,
Sorry to hear of your continuing woes - seems you are unlucky at the moment. Probably suggesting the obvious but have you tried a full bios reset - shorting the bios pins and maybe removing the battery for a while? It maybe that the last bios update you did has not fully initialised or completed.
May be worth a try.
Mark
If you remove all the drives windows could boot from the system enters bios by default.
Are you on about the Msata card here???
found the parts.my little girly had picked them up.any way I have it all up and running.I have two ssds in raid in the Intel 6gb slots and two ssds in the Intel 6g slots. I have installed the latest rst driver but irstor won't open.I want to raid the other two ssds.
There are only two intel 6gb ssd ports mate others are on Asmedia controller.
