i'm going to ask a couple of dumb questions:-
how do i check my cards temp whilst gaming, or is it possible to check what it was after i quit gaming
plus, should the cards fans be on auto, or manual/ custom, because right now they're on auto 30%
thanks
As the other chap said, look in the afterburner config, check GPU temp and tell it to display in OSD and you're ready to roll
As for fan control its up to the user, depending on what card you have you may get away with leaving it auto, the Lightnings TFIV cooler kept things nice and cool for me on auto.
What's the max safe volts on air for a typical 7970? Can't find the answer on google. Max temp 54c in heaven at 1200/1600 1250mV.
For a ref 7970 I'd say 1.25v is getting pretty close to the limits I personally would be happy with on air, but each to their own, one thing to keep in mind is the temps of the VRM's, not all cards show a temp read out for them, they can get a lot hotter than the core.
