Unfortunately your PC is not.![]()
perfectly fine.
No but in terms of server stability, and over population?
perfectly fine.
outland alliance and kazzak horde.
What server you guys playing? Alliance or Horde?
loads of ocukers on moonglade alliance too
Probably yeah, if you don't mind the odd death then go with PvP, will be a lot more enjoyable playing world pvp, so far from about 6 hours of playing I've only had 2 horde attack me out of seeing around 200, the rest I've started the fight![]()
not sure if theres an ocuk guild on kazzak, make sure if you play kazzak you play horde, if you want alliance go to outland.
Fair enough. I made Tomlir a Blood Elf mage.
press O and above the friends/ignore/pending tag should be your name and number, what is that? if you don't have one then you've probably not enabled it.
Anyone else making money?![]()
lol **** RP servers
